small port in which model
08-25-2007, 02:18 PM
Dear all,
I was just wondering in which models and which years the small port is used ? If I look for parts etc I always look at the AE 92 but it seems this car also came with 4 af and 4 afe ? The corolla GTi ( 1987 - 1993 )uses the small port but others ? If I need a head gasket for instance etc I do not think there are any differences between 4age´s ? http://www.heerlijklimburg.nl |
08-25-2007, 02:39 PM
jos 4 age Wrote:Dear all, AFAIK only AE92 GTi ... in Europe. Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62 |
08-25-2007, 02:51 PM
jos 4 age Wrote:Dear all,I have a 1990 AE92 GTi , there was a small port 4A-GE (nowadays it is in my AE86). I also have a three AE92 GTi's (1988-89) and all those have a big port 4A-GE. Original small port head gasket P/N is 11115-16070, if needed. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
08-25-2007, 06:37 PM
thanks !
is the head gasket from the small port different from the big port than ? I think it is. should I use original one ? It is always difficu´lt to explain in the shop that you need a head gasket for a 4 age small port as mostly they can find 4 age but there are several 4 age´s of course... http://www.heerlijklimburg.nl |
08-26-2007, 10:19 AM
Any 4A gasket (maybe any A-gasket) can be used. There is a difference but 4AGE gaskets are equal. Diference is larger water passages etc.
08-26-2007, 12:54 PM
I read somewhere that the 7AFE head gasket is thinner, and good for the 4AGE. I bought one and it is thinner but the water passages are absolutely not at their right place. With some dremel and diamond cutters I made these holes, but by this time I didn't try it. Hope it will work, but doesn't worth the work to do it.
The smallport and bigport 4AGE's have the same headgasket. By part number also the same. 11115-16070 as I remember. jamiemirror Wrote:Any 4A gasket (maybe any A-gasket) can be used. There is a difference but 4AGE gaskets are equal. Diference is larger water passages etc. |
08-26-2007, 01:46 PM
thank you for the info ! i can just order a 4 age head gasket now
20v BT - which oil pump? | Mylesmck | 4 | 2,813 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,518 |
Rim width. Which is best.... | Dino86 | 5 | 6,796 |
Small Port Swap | Alex170984 | 1 | 4,185 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,348 |
