spring platforms
03-31-2010, 09:57 PM
spring platforms
Stock struts, I want to cut and (professionally) re-weld the platforms 20mm higher.
any issues with this ? An analogue brain in a digital World |
04-01-2010, 10:15 AM
spring platforms
Not if you do it carefully.. Robokill used to have rally struts modified in this way (that are now coilovers in Doc's KE20). I'd use some beefy bumpstops so you can get to the end of a stage if a platforms fails.
04-01-2010, 01:17 PM
spring platforms
Thankyou.
Great idea with the bumpstops ! An analogue brain in a digital World |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 13,571 |
05-04-2015 01:17 PM Last Post: Project D |
clutch pedal return spring | Eifelaner | 2 | 7,334 |
09-06-2013 10:21 AM Last Post: Apsogos |
P-valve CLOSED --> Stiffer spring will do it :) | Dino86 | 1 | 3,299 |
04-05-2012 04:17 PM Last Post: Dino86 |
lowering spring information HELP | martyg | 1 | 3,481 |
09-27-2011 01:56 PM Last Post: martyg |
clutches and spring washers position in 2 Way TRD diff???? | T_AE86 | 3 | 5,260 |
09-01-2011 10:50 AM Last Post: T_AE86 |
