sr5 idle help
06-16-2008, 12:37 AM
sr5 idle help
ok so i have a few Q for any of you that knows about carbs and the sr5. im new to carbs but i understand how they work. ok so first off when i start it off it will idle good if i have the idle set at 1500rpm but if i lower it than it will not stay steady, it will stay with in about 300 rpms tho, and it will start to get ruff at around 1000 to 800 and will sometimes die at around 800. now my second Q is when its warming up if i give it gas than it wold idle, if i give it gas than let off the gas than it will just die. i know alot of stuff about EFI but carbs i only know the basics of the basics so i dont really know much about them other than miner adjustments and how most of them work so any help would be nice.
06-16-2008, 09:56 AM
sr5 idle help
You only set the idle screw when engine is warm, just like EFI. Otherwise it won't idle correctly.
![]() Then the carburetor has a choke (comparable to the coldstart injector) and it is probably an automated choke (like most modern carbed cars have) so you better check if it is still working correctly. I think this what your problem possibly is. ![]() Here you can find more info about how a carburetor works: http://auto.howstuffworks.com/question377.htm 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-17-2008, 01:10 AM
sr5 idle help
Have you checked the condition of your fuel pump?
06-21-2008, 10:42 AM
sr5 idle help
hey thanks for the help.. sorry it took so long for me to get back.. my computer was acting up... but well i took it to get smoged and my tac. said it was at 1,500 but the dyno somg thingy said i was at 670 RPM's lol so i think my tac is a bit off so i think i will try and get one that i can hook up to makesure i set it at the 800 i think it is suposed to be at. but thanks for the help. im also going to clean the carb up a bit and see how that helps it.
06-22-2008, 10:18 AM
sr5 idle help
I had such a problem with my tach in the past as well so that doesn't surprise me at all.
06-22-2008, 11:04 AM
sr5 idle help
Maybe its a good idea to get a clean air filter along the way as well if you haven't already done so.
06-24-2008, 08:22 AM
sr5 idle help
ya and my temp gage is really sticky and liks to jump around from all the way hot to all the way cold and back to norm sometimes. well when i got the car it didnt have a air filter so it has a nice new one
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,583 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,736 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,585 |
20v silvertop idle issue | AlexFourTwenty | 3 | 5,300 |
Silver top low idle | AlexFourTwenty | 7 | 10,450 |
10-16-2017 10:22 PM Last Post: AlexFourTwenty |
