stock brake pad?
12-17-2006, 11:09 AM
stock brake pad?
Hi !
Do you know if the brake pads of the AE86 are the same on another model ? AE92 etc ...?or other car Smile
thks
12-17-2006, 03:57 PM
stock brake pad?
Nopes..I'm affraid not... Here in Holland we have a large brake-selling company that you can go to. They take your old pads and compare them to overything they have in stock. Usually there is something in there that can be massaged into the calliper with the help of an angle grinder.
12-17-2006, 08:41 PM
stock brake pad?
they are different for sure
AE92 GTI front
http://www.autopartsonline.nl/nl/ao_list...&art=47646
AE86 Front
http://www.autopartsonline.nl/nl/ao_list...&art=47696
[Image: AEU86 AE86 - stock brake pad?]
12-17-2006, 09:16 PM
stock brake pad?
Carina TA60 have same front pads
12-18-2006, 05:08 PM
stock brake pad?
DJexor Wrote:they are different for sure
AE92 GTI front
AE82, AE92 and Celica ST162 ... if helps anybody
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
12-18-2006, 06:24 PM
stock brake pad?
Wasnt there some old mitsubishi lancer stuff that fitted? I think Zax mentioned that once..
12-18-2006, 06:28 PM
stock brake pad?
I think you are right, Ivan. I bought some Mintex 1144 for a mitsubishi (I think) that is suppose to fit in the rear calibers with a few mods Smile
12-18-2006, 06:35 PM
stock brake pad?
Honda Silverwing GL 500 1978-86 (motorcycle) front pads = AE86 rear pads
12-20-2006, 03:41 PM
stock brake pad?
I use stock brake pads on my ae86 previous owner was always going with this hachi to toyota services so when i checked i discovered they are also toyota brand or brand from that are made stock brake calipers. I think that they are really good.
85' AE86 GT coupe lifetime project since 2005
12-20-2006, 04:15 PM
stock brake pad?
Ryo Wrote:toyota brand or brand from that are made stock brake calipers. I think that they are really good.
Aisin..
  Digital speedometer on stock dashboard FanIsHere 0 2,744 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 4,621 11-24-2021 04:26 PM
Last Post: apardal
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 17,121 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 7,441 03-24-2019 04:10 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 7,219 02-20-2016 11:48 AM
