stock strut shocks (rally)
11-09-2008, 03:28 PM
Again in trouble with worn shocks on my AE86 rally car .
I'm searching shocks with a stock length strut , as hard as my former blue Tockico :48511-AE891. I also had Bilstein shocks , but they are HD , too soft for rallying . I'd like to keep stock strut lenght , and don't want coilover for now . Any idea , suggestion , links or shops welcome . Phil Filh Save the RWD cars |
11-09-2008, 04:38 PM
| stock strut shocks (rally) | |||
11-09-2008, 05:50 PM
tokico blue is a .... shock. Bilstein has really good rally shocks. (the ones you can adjust) Koni will never die but the rebound isn't to good.
Tokico HTS? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
11-09-2008, 08:35 PM
KYB AGX?
Half the price of the HTS.. Rokuichi Power !! _________________________________________ Toyota Starlet KP61 2.0 vtec |
11-09-2008, 11:01 PM
Phil just get the Bilsteins re-valved. 300-70 for tarmac (front)
I use these on my tarmac rally car with Spax adjustables on the back. An analogue brain in a digital World |
11-10-2008, 12:16 AM
[u:815b4ef754]To Eric[/u:815b4ef754]: not really : these are Monroe Gasmatic
Koni are banned for me , as they have a poor reability ( got some pairs worn) Bilstein is great , but they don't provide adjustable shocks for teh ae86. [u:815b4ef754]To Totta Corolla[/u:815b4ef754] : I got worn HD , I 'll contact a guy who's doing rebuilding to know if he get them hardened. Hope 300-70 will speak to him. To Sx Machine : will try to find The kyb agx , but I don't know if they're hard enough for rallying . Thanks for your advices Phil Filh Save the RWD cars |
11-10-2008, 01:33 AM
I've search about KYb AGX , and read that rear MR2 shocks can be used !
But do they fit the stock strut or are they short strut . I also found that that spacer can be used , to keep the stock strut? Any experience welcomed Phil Filh Save the RWD cars |
If you already have the Bilsteins then a rebuild / re-valve of them would be cheaper and most probably better for your application. About 90 Euro each in the U.K
I chose 300-70 as this is the Group 4 MK2 Escort tarmac spec. Speak to your man he may have other ideas about the rates. Personally and speaking from experience I don't think adjustables are absolutely necessary for rally. TC An analogue brain in a digital World |
11-10-2008, 10:29 PM
i agree , I'm not sure about adjustable shocks necessity on rallye applications (speaking about front suspension)
. What kind of springs do you use on front, and what rate ? I also need springs for rear , as they are used and now too short. I've see the Camaro Kyb adjustable shocks , that should be a good alternative . Phil Filh Save the RWD cars |
11-10-2008, 10:59 PM
I use 2.25" I.D race springs on coilover struts (converted standard struts)
10.5" 350lb I may go lower with these rates though, probably around 280lb Is yours a gravel and / or tarmac car Phil ? An analogue brain in a digital World |
| Digital speedometer on stock dashboard | FanIsHere | 0 | 2,752 |
| 82mm Stock compression Pistons | apardal | 4 | 4,630 |
| rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 5,605 |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 17,149 |
| Most stock-resembling exhaust for the AE86? | DaLanZhu | 4 | 7,446 |
03-24-2019 04:10 PM Last Post: oldeskewltoy |
