stock strut shocks (rally)
11-09-2008, 03:28 PM
Again in trouble with worn shocks on my AE86 rally car .
I'm searching shocks with a stock length strut , as hard as my former blue Tockico :48511-AE891.
I also had Bilstein shocks , but they are HD , too soft for rallying .
I'd like to keep stock strut lenght , and don't want coilover for now .
Any idea , suggestion , links or shops welcome .
Phil
Filh
Save the RWD cars
11-09-2008, 04:38 PM
http://link.marktplaats.nl/206678824
like these?
11-09-2008, 05:50 PM
tokico blue is a .... shock. Bilstein has really good rally shocks. (the ones you can adjust) Koni will never die but the rebound isn't to good.
Tokico HTS?
11-09-2008, 08:35 PM
KYB AGX?
Half the price of the HTS..
Rokuichi Power !!
_________________________________________
Toyota Starlet KP61 2.0 vtec
11-09-2008, 11:01 PM
Phil just get the Bilsteins re-valved. 300-70 for tarmac (front)
I use these on my tarmac rally car with Spax adjustables on the back.
11-10-2008, 12:16 AM
[u:815b4ef754]To Eric[/u:815b4ef754]: not really : these are Monroe Gasmatic
Koni are banned for me , as they have a poor reability ( got some pairs worn)
Bilstein is great , but they don't provide adjustable shocks for teh ae86.
[u:815b4ef754]To Totta Corolla[/u:815b4ef754] : I got worn HD , I 'll contact a guy who's doing rebuilding
to know if he get them hardened. Hope 300-70 will speak to him.
To Sx Machine : will try to find The kyb agx , but I don't know if they're hard enough for rallying .
Thanks for your advices
Phil
Filh
Save the RWD cars
11-10-2008, 01:33 AM
I've search about KYb AGX , and read that rear MR2 shocks can be used !
But do they fit the stock strut or are they short strut .
I also found that that spacer can be used , to keep the stock strut?
Any experience welcomed
Phil
Filh
Save the RWD cars
If you already have the Bilsteins then a rebuild / re-valve of them would be cheaper and most probably better for your application. About 90 Euro each in the U.K
I chose 300-70 as this is the Group 4 MK2 Escort tarmac spec. Speak to your man he may have other ideas about the rates.
Personally and speaking from experience I don't think adjustables are absolutely necessary for rally. TC
11-10-2008, 10:29 PM
i agree , I'm not sure about adjustable shocks necessity on rallye applications (speaking about front suspension)
What kind of springs do you use on front, and what rate ?
I also need springs for rear , as they are used and now too short.
I've see the Camaro Kyb adjustable shocks , that should be a good alternative .
Phil
Filh
Save the RWD cars
11-10-2008, 10:59 PM
I use 2.25" I.D race springs on coilover struts (converted standard struts)
10.5" 350lb
I may go lower with these rates though, probably around 280lb
Is yours a gravel and / or tarmac car Phil ?
  Digital speedometer on stock dashboard FanIsHere 0 1,359 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,741 11-24-2021 04:26 PM
Last Post: apardal
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,181 07-25-2021 04:41 AM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,338 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,553 03-24-2019 04:10 PM
