stock strut shocks (rally)
11-10-2008, 11:40 PM
Most rallye here are Tarmac , with some gravel part . Lets consider it's tarmac only .
I tried coilover ( stock struts lenght and blue TRD/Tokico ) with Swift springs 8kg/mm( I think it's 400lbs) , but it was too soft .
I got my large springs back on stock strut plate .
I was planning to buy 12", 500lbs spring (60mm dia) from Rally design, and try them with Bilstein rebuilded shocks
phil
Filh
Save the RWD cars
11-10-2008, 11:47 PM
filh Wrote:I've search about KYb AGX , and read that rear MR2 shocks can be used !
But do they fit the stock strut or are they short strut .
I also found that that spacer can be used , to keep the stock strut?
Any experience welcomed
Phil
Yes, the MR2 version is short stroke.
It's the front btw.
But they also have normal stroke version's for the AE86.
The MR2-front/Camaro-rear option is for extreme lowering.
Techno Toy Tuning sell's the spacer right here:
http://www.technotoytuning.com/productdetail.php?p=110
Rokuichi Power !!
_________________________________________
Toyota Starlet KP61 2.0 vtec
11-11-2008, 12:20 PM
AGX and HTS won't do you much good on a rally car, both are short strokes and will drop the height.
11-11-2008, 12:50 PM
Mux213 Wrote:AGX and HTS won't do you much good on a rally car, both are short strokes and will drop the height.
See my abobe post...
Shock's don't alter rideheight.
That's what springs do.
Rokuichi Power !!
11-11-2008, 08:50 PM
filh Wrote:Most rallye here are Tarmac , with some gravel part . Lets consider it's tarmac only .
phil
Perhaps I should stiffen mine up a bit then Huh Please let me know what it's like, I have a tarmac rally between Christmas and new year and might give these rates a go.
11-12-2008, 01:13 AM
To SX-Machine : confirming , the height is done with springs , shocks work is to absorb the spring "oscilliation"(don't know if it's the correct word in english to speak about spring movement)
So if I read well , despite Bilstein, there's no alternative on shocks with stock lenght .
To Totta Corolla . Will leave you feed back , but my next rally is on december 13/14 , and I don't know if I can get all fixed for that date!
Phil
Filh
Save the RWD cars
11-12-2008, 01:38 AM
KYB agx has stock lenght... Just look at there website.
Koni has stock length. (I had them)
Rokuichi Power !!
03-19-2009, 01:51 AM
What are the lenghts of Bilsteins ?
03-20-2009, 08:57 PM
Uzelac Wrote:What are the lenghts of Bilsteins ?
Stock height. (not short stroke)
03-20-2009, 10:00 PM
Have you tried TRD??
Last time I check with the dealer here, they still have standard length front shocks.
and its adjustable.
  Digital speedometer on stock dashboard FanIsHere 0 1,550 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,994 11-24-2021 04:26 PM
Last Post: apardal
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,525 07-25-2021 04:41 AM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,865 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,801 03-24-2019 04:10 PM
