technical asking about TVIS
02-27-2011, 01:02 AM
Hello,
As I'm fixing a standalone ECU system (E-Race) I need some informations about TVIS .
Is it fully open at +/- 4000 rpm or higher (4500 rpm)
What's voltage is applied to the blue part on T-Vis ( I think it's named VSV Vacuum Switching Valve)
Is it 12v or 5v ?
Thanks for helping
Filh
Save the RWD cars
02-27-2011, 01:49 AM
4200 rpm and 12V Smile
Good luck....
Cheers... jondee86
02-27-2011, 01:50 AM
Hi Filh,
It's 12V, and I very much doubt it does anything as subtle as opening partially. Switching point should be somewhere round 4100-4300, but this is based on the original engine characteristic. If you really need to keep TVIS, I'd try to figure out at what point the restriction from closing TVIS starts to hurt power.
02-27-2011, 02:07 AM
Thanks for helping
Yvan , you're right , it's on /off position , fully open , or close .
To get the best TVIS openning revs , we'll see that on Dyno bench .
My asking was more about voltage , and I got the response very quickly
( was sure , you and Jondee were around)
Respect! Respect!
Regards
Phil
Filh
Save the RWD cars
  Early tvis red top from e9 gti small or bigport? Ryo 3 8,115 04-20-2018 09:14 AM
  Tomei 16V poncams + Tomei technical trax 1.5 way LSD Lt86 22 21,848 09-16-2016 09:56 PM
Last Post: Alex170984
  20v silvertop exhaust manifold on 16v 2nd version tvis motor Apsogos 17 23,904 11-22-2012 11:15 PM
Last Post: Apsogos
  my tvis doesnt work... daywalker 30 51,283 02-19-2012 01:25 PM
Last Post: ZDoman
  Richieu -Technical help desk richieu 25 40,399 08-31-2011 10:32 PM
Last Post: NightAddict
