the connector saga (please help everyone)
12-20-2012, 09:21 PM
(This post was last modified: 06-23-2014 12:10 PM by Bean.)
Due to personal need I was on the look for the crimp receptacles for the harness ECU plugs... after I managed to get the part numbers (thanks Project D) I thought why not try to find them all, so here goes - anybody that knows something PLEASE chip in:
Injectors are Bosch EV1 style, as far as I know here are all the TE part numbers for the Nippon Denso 42 (10-18-14) connector (made by Tyco Electronics Japan): Code: 170352-2 PULSE LOCK CRIMP CONTACTS I'll try and keep this first post up to date, any info is welcome AE86 ex-daily |
12-21-2012, 03:41 PM
If I find anything I will post them here :wink:
12-25-2012, 02:33 PM
Last time I tried getting my hands on the ECU receptacle it proved pretty much impossible in the Netherlands. Back then I worked at a PCB assembly fab and tried to get one through the purchases department. Might be good to check availability as well.
12-27-2012, 08:56 AM
Some general info for all you people (re)building wiring harnesses:
http://www.rbracing-rsr.com/wiring_ecu.html http://www.rbracing-rsr.com/sq6wiringloom.html At least I found them interesting/useful! JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
12-27-2012, 10:56 AM
Bean I know this probably is not much use to you but it may help someone
in the future that does a search. When I went to smallport injectors and I wanted to keep my bigport loom intact I used a selection of these plugs / sockets to make a plug in jumper cable. In my case I used smallport injector pig tails with the male timer plug fitted to the other end to plug into the loom: http://www.ebay.co.uk/sch/m.html?_nkw=ti...workshop27 An analogue brain in a digital World |
12-27-2012, 12:06 PM
This is absolutely fine. The intent of this thread is to accumulate all plug/wiring related things we know, so every bit helps
I'm currently trying to find the plugs (both ends) used on the ignition side of the 4AGE (distributor, igniter etc of all versions). Unfortunately so far I only hit dead ends makes me wish I had kept my spare loom, though it would have been a pity to cut it up. AE86 ex-daily |
06-23-2014, 12:06 PM
10pin ECU plug housing, 18pin ECU plug housing
, ECU plug housing contacts (50pieces), Injector connectors (BOSCH EV1) , AE86 ex-daily |
06-23-2014, 12:56 PM
Wow.... you found them...
06-23-2014, 01:13 PM
(This post was last modified: 06-23-2014 01:14 PM by Bean.)
Did find them a long time ago see top post but couldn't buy them until now as they wouldn't sell to me when I was in Europe (as I'm not a registered business).
Guess you don't need them anymore with the 20V swap (different plugs anyway). Sent from my Nexus 4 using Tapatalk AE86 ex-daily |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 6,770 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Carb question please help | MIGGZFSU | 3 | 4,599 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
which connector is this | ditn | 7 | 7,534 |
07-27-2015 11:24 AM Last Post: pack |
Whining noise HELP PLEASE | izanagi | 10 | 11,994 |
03-26-2015 06:48 PM Last Post: Komba |
help, puzzled by the radio connector | Bean | 4 | 5,871 |
11-17-2014 11:32 PM Last Post: banpei |
