thread size stock nut for shocks
01-07-2009, 02:16 PM
i'm getting confused now.
i have stock nuts (which fit my Tokico HTS shocks) but which size of thread do those nuts have?
M14x1,5?
M12x1,25?
01-07-2009, 04:16 PM
Why don't you measure the Tokico thread?
Measure the diameter with a vernier or rule - around 14~15 will be M14, 12~13 will be M12.
Then measure the distance for 11 threads i.e. 10 thread gaps. Divide the measured value by 10 and you've got the thread pitch.
Easy!
My guess would be M14 for the front struts and M10 or M12 for the rear dampers.
Note most nuts/bolts have two thread types - Fine and Course, each has a different pitch.
Some manufactures stick to one pitch type but others change depending on application.
01-07-2009, 09:34 PM
ah, didn't know how to measure it!
will do that!
thanks!
  Digital speedometer on stock dashboard FanIsHere 0 1,512 11-09-2022 01:36 PM
Last Post: FanIsHere
  82mm Stock compression Pistons apardal 4 2,940 11-24-2021 04:26 PM
Last Post: apardal
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,448 07-25-2021 04:41 AM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,782 07-18-2019 03:52 PM
  Most stock-resembling exhaust for the AE86? DaLanZhu 4 5,770 03-24-2019 04:10 PM
