too small!
10-06-2005, 09:42 PM
too small!
i have had 205/60-13 and they drifted fine. lasted maybe 30mins. i also have used. 165/70, 165/75, 175/70, 185/70...the only thing is that they generate heat faster because they spin faster. so if you drift for 30mins straight. you will chance the tires to blow from over pressure. usually they ruptured out the sidewall. i didnt care to air out the tire after drifting. i just run them until they blow. good thought to keep in mind.
but after a while, 13 is just too small. sure tires are cheaper. but 15s look nicer on 86. and better for higher speed drift. also, 13s have a sloppy sidewall. and bounce too much for drift. even if you stretch the tires on. |
10-07-2005, 07:44 AM
too small!
I think 13's are pretty cool...I wouldnt expect 8(!!)x13 to loose traction THAT easily..Seen plenty of irish hachi's riding on 13's on pictures, I guess it's one of those preference things again. Personally I think 15's are a tad to big for the hachi. 14" is my ideal..it's just that the choice of nice wheels in 14 inch is a bit limited over here.
10-07-2005, 09:43 AM
too small!
Remember that the early spec car came with 13's as the standard alloy here in the UK, some thinking suggests that you only should go up one size, remember it in some japanese video
10-07-2005, 10:31 AM
too small!
Were did you find the wheels oin the pic?
And what is the price. It would look really great,lowered 100mm,and then these wheels Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
10-07-2005, 10:54 AM
too small!
looks great but and will drift great with them
10-07-2005, 12:24 PM
too small!
£350 delivered with centres etc from RareRims in the UK. They have available
Steel Grey Silver or black without polished rim. Dave |
