trd solid spacer how to?
04-19-2012, 07:18 PM
how do i know what shim i have to use of my trd solid spacer?
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
04-19-2012, 07:35 PM
I believe you need to measure the rotational torque, afaik it's only purpose is to adjust preload for the pinion bearings. Just pick the shim that gets it within spec.
04-19-2012, 07:55 PM
but how do i measure it? with picture please.
04-19-2012, 07:56 PM
04-19-2012, 10:11 PM
Don´t waste your time, give it to a diff/ G-box shop.
The cheapet tool to do the job costs 340Euro. That´s twice as much money as you need to get it done in a shop! 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
04-19-2012, 10:38 PM
IIRC Weir Performance had a good writeup on their website of how to
intall a solid pinion spacer. EDIT: My bad... I was thinking about the LSD upgrade kit. Pretty sure for the spacer you assemble and torque to spec, then check the preload. Too much preload, add a thicker shim. Not enough, use a thinner shim. Assemble, torque to spec and check preload. Repeat as many times as necessary to get the preload correct. Cheers... jondee86 |
04-20-2012, 04:15 AM
It's the same as setting up any 'crush' sleeve, but instead you shim it until it reaches spec.
If you do NOT know how to do this already, I would definetely recommend taking it to someone/somewhere that IS experienced. This is not a job for beginners. Andrew |
04-20-2012, 07:01 PM
thanks. i can do this. but i do not know what the trick is. yet.
04-20-2012, 11:17 PM
Hello ,
you can use a stock shim to adjust the preload. Remove it and measure it . You cut the solid space to the same measurement. It needs a great precision. That's how my machinist do it . If your interested, he's located in Belgium (Hannuit) ,not so far from you. I can give you the address and phone (he speaks english) Regards Phil Filh Save the RWD cars |
04-21-2012, 05:19 AM
If you buy the real TRD, install the pinion bearings, the TRD solid spacer + ALL shims. Assemble the pinion gear WITHOUT installing pinion seal. Check pre-load, if too little, remove shim and recheck until it is proper.
Andrew |
| 4 Puck Solid Clutch Disc | filh | 11 | 14,271 |
11-07-2011 11:40 PM Last Post: filh |
| wheel rim spacer center bore, 60mm ? | Uzelac | 4 | 11,721 |
01-21-2010 08:10 PM Last Post: aussiefan |
| Tokico HTS spacer? | Bubble_Drift | 27 | 34,815 |
07-08-2009 06:43 AM Last Post: Euripides |
| Solid Engine Mounts? | PazzaAE86 | 4 | 6,616 |
03-11-2009 12:30 PM Last Post: Ivan141 |
| Solid rear brace? | Spitfire | 18 | 21,271 |
07-20-2007 11:02 PM Last Post: assassin10000 |
