undoing the dashboard, need TIP
01-25-2005, 02:36 PM
The answer is apparently something easy and obvious,
but besides I 've allready spend some time unscrewing every bolt on the down half of my dashboard do to the turbo timer and hallmeter instalation, I havent managed to do the same with the upper half. Plz check pics and help me: danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
01-25-2005, 02:54 PM
Okay..I've been there a few times. To get the part around the gaugecluster of there are 3 screws above the cluster (underside of overhanging bit of dash). You can pull off the light and wiper switches, underneath are some big nuts, take those off and you can pull off the part of the dash without any problems. I've only listed the bits that arent obvious, any other nuts and bolts in plain sight should also be taken off if they attach to the dash.
01-25-2005, 03:06 PM
thx i'll inform you soon
01-25-2005, 03:35 PM
Yeah sounds pretty much like what I did.
I had some problems with the steering wheel getting in the way when I took out my instrument cluster though... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
01-25-2005, 03:50 PM
he wont have that problem with the smaller steering wheel he has.
Anyway, I managed to get it in without breaking anythin on senna's car, so it is possible. FABRICA MI DIEM, PVNC! |
Digital speedometer on stock dashboard | FanIsHere | 0 | 1,945 |
Tip! Oil funnel. | krullibull | 2 | 4,291 |
06-04-2013 12:59 AM Last Post: fax0815 |
Dashboard 1984 vs 1986 | Dino86 | 3 | 4,850 |
11-08-2012 09:39 AM Last Post: Dino86 |
Stack dashboard in AE86? | ZaX | 2 | 5,995 |
01-27-2012 11:07 PM Last Post: NoHachi |
Tip: replace shifter bush! | danielvanderwoude | 1 | 3,504 |
09-18-2009 12:14 PM Last Post: danielvanderwoude |
