upgrading brake system
05-13-2012, 11:11 AM
sadziak Wrote:
aussiefan Wrote:RX7 FC or FD - the calipers are almost the same, just some optical differences.
This setup will fit under 15" wheels and under some 14" wheels, depending on wheel design and offset.
you can find a few pictures in my thread
http://www.aeu86.org/viewtopic/sharing-k...er/t/12560
Hi, there is a difference between FC and FD. FD are from Aluminum and are much much lighter!
hi have done the conversion.
i recommend it a lot.
you need:
- Mazda FD3S 4 pot calipers - should track them on UK Ebay for about 90-120GBP) - depends on condition,
- good brake pads, mintex High Performance, Ferodo DS, Tarox, hawk HPS - you name it..
- good steel braided brake lines - i have HEL, you can buy also Goodridge,
- good high temp = high performance braking fluid (RBF 660),
- caliper mounting adaptors - you can buy them on ebay from USA (about 150usd+shipment+taxes...they come in aero-grade billet aluminum, very strong and very light with bolts 10.9 grade to mount them - should work plug and play) or you can dig the 4age forum for a CNC Machine Drawing file and try to make them in a local CNC Shop, but i assume they will not be much cheaper to do a single pair.
- new Mini Cooper S Rotors (272mm) - need to be redrilled at a workshop to fit, i recommend the ATE POWERDISCS (sloted) - good price for the performance, but you can also go for Tarox Sport Japan or DBS from Austraila if you have the money...$$
- bigger = more efficient braking Servo!! try important, you will not have enough braking power for the 4 pot calipers if you don't have a bigger braking servo!! a servo from a NISSAN 200SX s13 will do the job!
thats it, thats All.
FC calipers are made from aluminium also...
Messages In This Thread
upgrading brake system - AE86-SA - 05-05-2012, 01:08 AM
[] - fax0815 - 05-05-2012, 02:18 AM
[] - AE86-SA - 05-05-2012, 06:54 AM
[] - bozu - 05-05-2012, 10:12 AM
[] - AE86-SA - 05-05-2012, 02:29 PM
[] - AE86-SA - 05-08-2012, 01:59 PM
[] - aussiefan - 05-08-2012, 02:35 PM
[] - AE86-SA - 05-09-2012, 12:35 AM
[] - aussiefan - 05-09-2012, 01:12 PM
[] - AE86-SA - 05-10-2012, 02:26 PM
[] - sadziak - 05-10-2012, 09:55 PM
[] - sadziak - 05-10-2012, 09:58 PM
[] - AE86-SA - 05-11-2012, 12:15 PM
[] - sadziak - 05-11-2012, 12:35 PM
[] - AE86-SA - 05-13-2012, 12:47 AM
[] - sadziak - 05-13-2012, 01:37 AM
[] - [Walaki]D`Lair - 05-13-2012 11:11 AM
[] - sadziak - 05-13-2012, 11:26 AM
[] - [Walaki]D`Lair - 05-13-2012, 12:25 PM
[] - sadziak - 05-13-2012, 02:37 PM
[] - AE86-SA - 05-14-2012, 02:07 PM
[] - [Walaki]D`Lair - 05-14-2012, 07:55 PM
[] - [Walaki]D`Lair - 05-14-2012, 07:59 PM
[] - sadziak - 05-14-2012, 09:30 PM
[] - sadziak - 05-15-2012, 02:13 AM
[] - sadziak - 05-15-2012, 02:16 AM
[] - [Walaki]D`Lair - 05-15-2012, 09:19 AM
[] - GTRJazz - 05-19-2012, 09:58 PM
[] - JGeorge - 05-20-2012, 12:12 AM
[] - GTRJazz - 05-20-2012, 01:12 AM
[] - Eircamae86 - 05-20-2012, 02:25 PM
[] - [Walaki]D`Lair - 05-20-2012, 03:44 PM
[] - TeZe - 05-20-2012, 05:56 PM
[] - Project D - 05-20-2012, 06:26 PM
[] - AE86-SA - 05-21-2012, 04:28 AM
[] - GTRJazz - 05-22-2012, 02:07 PM
  Stack display system, need help Jimmi The Kid 1 4,275 01-15-2017 10:52 PM
  How to rebuild the AE86's brake system all around Homem Bomba 7 13,850 07-02-2013 10:31 PM
Last Post: Homem Bomba
  Who has a Kakimoto R Exhaust system? Rick 4 7,781 06-19-2013 09:11 AM
Last Post: Mint_86
  Fuel system setup 86Pilot 2 4,739 01-30-2013 04:24 PM
  How does the 4age AFM system work? heshan 22 24,062 12-20-2012 05:01 AM
Last Post: heshan
