what injectors?
03-04-2013, 01:17 AM
what injectors?
Hi, I have a stock 4AGE engine with 272 hks cams and trd ecu, need big injectors. the originals are low impedance.
Thanks from canary island. |
03-04-2013, 07:27 AM
what injectors?
The 22RTE engine injectors a fine for that. they are 250cc at 2.5B
It's the injectors used in many race car (Group A and N) It's what it was on my car whene i buyed it. SR Team BURN THE RUBER NOT YOUR SOUL! |
03-04-2013, 10:22 AM
what injectors?
I used Bosch 0280150201 from Porsche 944.
They are specified for: 258cc @3Bar and 2.4 ohm. If you can adapt fueling for different injectors, anything similar will be fine. |
03-04-2013, 04:22 PM
what injectors?
thanks guys, BOOMEX what reference have the injectors?
03-04-2013, 05:16 PM
what injectors?
Use the ones from a Supra, 450cc, 3Bar and low impedance, or the ones from a 4agze engine, 365cc, 3Bar and low impedance, think the ones from a 4agze would be fine for your setup
Restoring my AE86, all the way... Going JDM style http://www.aeu86.org/viewtopic/ae86/p/150463#150463 |
03-04-2013, 05:58 PM
what injectors?
i have a red injectors from 4agez but is very big with my ecu trd, in low revolutions is slow.
I need 220cc. |
03-04-2013, 06:19 PM
what injectors?
anything over 300cc is too big for this setup. (still can work, but with a TRD ECU i doubt you can fine tune the injection)
Injectors from honda (like civic before 91, with the blackish plastic tip) are fine ![]() 240cc @ 3bar and a wide atomisation (perfect for a 4AGE) and same connector Toyota 4age injector (green) VS D16A6 injector: |
03-04-2013, 06:27 PM
what injectors?
Project D Wrote:Injectors from honda (like civic before 91, with the blackish plastic tip) are fine Odd.... in the USA the mid/late 80s Accord, and Prelude with the 2.0i engines had beige/tan injector color, they were/are also 240cc and low ohm. It is the mod I recommend when putting in ANY aftermarket cam (256, or 264) Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-04-2013, 08:25 PM
what injectors?
Actually most Honda had / still have 240cc injectors,
peak and hold for the oldest (most of the time with a resistor box for the late 80' at least) saturated for the most recent. So you can find them with a different color / part number I believe :wink: Anyway, if you have the part number, it's easy to check what they are
03-05-2013, 02:19 AM
what injectors?
ok, then I find the Honda?
The blue top injector? is small? |
| INJECTORS ADVICE. | CHOPKIN2 | 9 | 10,239 |
07-12-2018 12:04 AM Last Post: CHOPKIN2 |
