which piston is this?
06-27-2014, 11:21 AM
Which piston is this?(smallport?)
Found it together with a 40mm crankshaft in a blacktop Huh
[Image: AEU86 AE86 - which piston is this?]
06-27-2014, 01:06 PM
i think its from big port
pistons pin 18 crack 40 = big port blue or red valve cap
pistons pin 20 crack 42 = small port only red valve cap v same is 4agze supercharger 2 gen 3 gen
not 1 gen is the same with big port
thats i know i hopre hepl u
06-27-2014, 01:17 PM (This post was last modified: 06-27-2014 01:17 PM by ditn.)
thanks for info Smile
Forgot to add some extra info.
the pin is 20
the crank is 40 100% sure
So maybe late bigport or i mismeasured the pin
But how can this be in a blacktop 4age? thats the mystery i dont understand
06-27-2014, 04:14 PM
Not a genuine Toyota 16V piston, maybe Honda?
Sent from my Nexus 4 using Tapatalk
06-27-2014, 10:23 PM
Hm this is getting weirder and weirder
Aftermarket not possible?
How can honda pistons work with a blacktop?
06-27-2014, 10:46 PM
(06-27-2014 10:23 PM)ditn Wrote:  Hm this is getting weirder and weirder
I never exactly looked into it but apparently there's a compatible piston from Honda with almost the same specs.
06-27-2014, 11:34 PM (This post was last modified: 06-27-2014 11:54 PM by zenki.)
4afe with the same piston
ハチロク
06-30-2014, 10:38 PM
aha ok thanks.
Is a 4afe crank usuable in a 4age?
07-01-2014, 03:33 AM
Yep, its a 4AFE piston, unfortunatly they are pressfit wristpin like the bluetop engine. They are low comp so maybe someone was trying to build a turbo engine?
Crank can be used, only downside whould be the 6bolt crank unstead of 8 bolt on 4AGE´s.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
07-04-2014, 02:09 PM
(07-01-2014 03:33 AM)fax0815 Wrote:  Yep, its a 4AFE piston, unfortunatly they are pressfit wristpin like the bluetop engine. They are low comp so maybe someone was trying to build a turbo engine?
ok thanks for the answer
Hm maybe its weird.
Hm unless im mistaken the crank actually was 8 bolts since it was a blacktop flywheel need to check
  20v BT - which oil pump? Mylesmck 4 3,069 06-21-2022 04:51 PM
Last Post: pack
  Piston ID kazi 5 5,828 08-11-2019 03:34 PM
Last Post: totta Crolla
  86mm piston wizards... fantapants 6 6,502 05-30-2017 02:36 PM
Last Post: jdm86gtz
  Rim width. Which is best.... Dino86 5 7,031 01-07-2017 03:09 PM
Last Post: Dino86
  Piston Identification Alex170984 3 5,617 05-17-2016 12:47 PM
Last Post: Alex170984
