will these wheels fit?
01-05-2010, 10:59 AM
like the tittle says,are they gonna fit on my ae86?the car is droped about +/-3cm now
tyre:195/50/15
Size: 15" x 7"
4 Lugs
4 Holes (PCD 4x114.3)
+40mm Offset
73 Center Bore
daily driver avensis 2.0 d4d and Yaris 1.0
weekend driver 1985 AE86
01-05-2010, 11:07 AM
will not fit..
you will need 20mm spacers on each side to make it fit
[Image: AEU86 AE86 - will these wheels fit?]
01-05-2010, 11:17 AM
ok then i know what i must do
thanx
01-05-2010, 11:27 AM
which offsets will fit then wiht a 15/7 rim?
01-05-2010, 03:01 PM
15x7: between +20 and -12 (stock arches)
with a positive offset the wheels will be deeper in the arches, so closer to the struts. I drove with a 15x7 offset +20 and 195x50/15 and it was about the minimum millimeters from the coilovers on my struts.
A negative offset will push the wheels further out of the arches, so if you would mount a -12 offset, you would have the flushed look. Wheels almost in line with the outer fenders. Cool for looks but i would not recommend it when you choosing 15x7.
If you stick to the idea of a 15x7, then i would search for a wheel close to offset 0.
01-05-2010, 07:54 PM
i had my eyes on these rims but it is just to much offset Sad
http://cgi.ebay.com/ebaymotors/15-EVOKE-...ccessories
01-06-2010, 12:38 AM
Roger Wrote:i had my eyes on these rims but it is just to much offset Sad
these wheels were available with 0 offset earlier. look after some shops, someone must have old stock of them
01-06-2010, 03:50 AM
look for rota or drag they both have 15x7 et0
AE86 owner
01-06-2010, 10:29 AM
problem is that those wheels are in 4x100, not in 4x114.3. Drag has them still available in low offset, but then you have to use a wheeladapter.
01-06-2010, 03:38 PM
http://forums.club4ag.com/zerothread?id=34212
Maybe he can still get them
  Mistlamps don't fit gh0st 1 2,346 10-14-2021 09:00 PM
  Can you identify this wheels? Will they fit AE86? Ryo 8 10,637 09-08-2021 12:48 PM
Last Post: Ryo
  Ae86 bulk head mod to fit hydrolic clutch? dinkers542 8 9,796 11-25-2014 09:21 PM
Last Post: dinkers542
  Are these modded TRD N2 flares? 4000GT 6 18,566 06-21-2014 12:16 AM
Last Post: 4000GT
  What injectors are these? Alex170984 4 5,975 08-05-2013 11:53 AM
Last Post: jondee86
