wiring aftermarket tachomete
05-19-2014, 05:43 PM
Hi all,
I would like to add an aftermarket tachometer to my AE86 but I don't know if it's possible and how to wiring that.
Thanks for your help.
05-19-2014, 08:18 PM
It should be perfectly possible as long as you have a tacho that is suitable for a four cylinder car.
You can look up which wire to pick up from the combination meter in the wiring diagram manuals (EU or USDM) or the body repair manual (page BE-22):
http://www.aeu86.org/technical/ae86-manuals/
Or you draw a new line from the coil directly and fuse it properly. I think last month's edition of Practical Classics had a nice how-to on the whole subject. I'll have a look if I can scan that article. Wink
[Image: AEU86 AE86 - wiring aftermarket tachomete]
05-19-2014, 10:39 PM
(05-19-2014 08:18 PM)banpei Wrote:  It should be perfectly possible as long as you have a tacho that is suitable for a four cylinder car.
Perfect.
Thank you mate.
05-20-2014, 09:18 AM
This morning I scanned the article and added it as an attachment.
Hope this helps you out. Wink
Attached File(s)
.pdf  pc-may2014-fit-tacho.pdf (Size: 332.21 KB / Downloads: 551)
05-21-2014, 02:38 AM
Generally speaking, most decent aftermarket tacho's can accept
5V square wave, 12V square wave or voltage spike inputs. If you
take the signal directly from the coil, you need a tacho that can
accept a voltage spike input, so check the tacho data sheet.
Square wave outputs are found on later model cars, and originate
from the ECU or igniter module.
Cheers... jondee86
05-21-2014, 07:03 AM (This post was last modified: 05-21-2014 07:06 AM by izanagi.)
Thanks for the help. I will check before buying.
Envoyé depuis mon GT-I9100 avec Tapatalk
(05-21-2014 02:38 AM)jondee86 Wrote:  Generally speaking, most decent aftermarket tacho's can accept
Cheers... jondee86
Any brand that it's sure it works to advice me ?
Thanks
05-21-2014, 08:28 AM
Hard to go wrong with VDO Thumbs up!
Cheers... jondee86
05-21-2014, 08:15 PM
Cheers... jondee86
I stand corrected here. Tongue
  Tail light wiring... Mylesmck 4 2,007 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 6,009 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 8,126 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 6,310 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 18,259 09-19-2017 02:06 PM
