Track AE86 Build from south america
10-30-2013, 01:02 AM
This project started 4 years ago, and it has been running for the last 10 months, so I finally decided to post it.
The car was bought with the intention to gradually transform it into a race car for the local historic racing series. The humble beginnings We built a cage, mounted a race seat, harness, new wheels and went racing on an otherwise fully stock car. The car developed severe cooling issues (that´s why you see the front mask removed in the picture) but since the engine was going out we decided to run the race anyway. It ran for 3 hours well into the RED zone in coolant temp, and miraculously finished third in stock class. After that, the car went for a full rebuild. This is a summary of the current setup: - Engine: Bigport 4AGE, HKS 272 cams, Wiseco high compression pistons, dual Weber 45 carbs, fixed ignition advance, stock crank/rods and everything else including the head. - Suspension: Koni yellows and TRD 6/4 springs. Tein camber plates. - Brakes: Rebuilt stock calipers, Hawk HT-10 pads - Chasis: Full cage, driver position moved 25cms backwards and 10 cms lower, Tilton pedals and pumps, new steering column. Ergonomics were treated as priority, as the car is intended for some endurance races. Specs: 156 whp, 895 Kgs with all fluids and 10l of fuel. This is the car now (watch in HD): This was its first real race, driving way too carefully: A few random pics: |
10-30-2013, 04:08 PM
This is an awesome picture:
Great work Sarcasme is just one of the things I offer Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch |
10-30-2013, 07:31 PM
It's a great car that you have
SR Team BURN THE RUBER NOT YOUR SOUL! |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,934 |
09-09-2022 09:07 PM Last Post: Vaptor |
OST-050 - a VERY special build | oldeskewltoy | 49 | 35,757 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
OST-051: One Lap of America | oldeskewltoy | 10 | 9,291 |
09-28-2018 05:30 PM Last Post: oldeskewltoy |
Trueno Coupe South Africa | MIGGZFSU | 151 | 105,528 |
06-07-2018 09:40 PM Last Post: MIGGZFSU |
d3nso's little AE86 N2 build | d3nso | 27 | 34,418 |
11-13-2017 11:42 AM Last Post: mad.matt |
