nzae86's AE86 Levin Tarmac rally car build Project 1
01-01-2008, 06:54 AM
I thought I would share one of my project builds that I started after destroying my Rally car on tarmac. I managed to salvage the engine , gearbox, and diff center and front brakes, the rest went to the dump!The seats broke , the dash was destroyed, it was easier to start again!
After finding another good shell my panel beater cut and butt welded any areas of rust to end with a rust free body to start building a new cage into, all the fabrication work i have done myself. The shell was then sent in and media blasted back to bare metal, the sprayed with PPG DP40 etch primer The cage did it's job ok last time but I added a bit more to it for the new car The shell then went to the painters to have the top coats sprayed in a oven |
01-01-2008, 07:08 AM
While the shell was away for paint I rebuilt all the other components, sand blasting everything and repainting, i also thoght it was time for a new engine as well , the other needed pulling apart to check for oil starvation while end for ending down the road, so a bit more power was added with new pistons and balanced bottom end.
All new bilstien suspension was fitted and the springs were replaced with TRD. After building a new fuel system for the car I had just finished when Motorsport New Zealand changed the rules on surge tanks and fuel pumps inside the car, so i had to redesign how it fitted and mounted it all in a sealed box |
01-01-2008, 07:24 AM
nzae86's AE86 Levin Tarmac rally car build Project 1 | |||
01-01-2008, 07:35 AM
01-01-2008, 07:51 AM
And for the finished article in action !!
One of it's first events, just to get it dirty ! at a rallysprint in the rain A small video, suffering from a nervous driver and very slippery conditions http://www.youtube.com/watch?v=b_lD1ooVwqU and another after passing the GT4 Celica http://www.youtube.com/watch?v=bgusB5tF3M8 Tarmac rally in New Zealand At a recent trackday enjoying the sunshine I am now running the car on 15 inch wheels and it suits the car very well, the rims are from a Dastun 240RS rally car , if anyone knows where I can find some more of these 15 x 7 let me know And at a recent Tarmac hillclimb, those Dunlops are fantasic, you can push them to the limit and they still hang on ! And yet another Tarmac rally in the rain !! Finished 16th O/A won 1400 - 1800cc class by over 2 minutes , take that you Honda's !!!! |
01-01-2008, 09:30 AM
thats sick... i luv 86 rally cars
how come u decide to use struts and springs instead of coilvoers?? and what brakes are u using??? |
01-01-2008, 12:25 PM
Very nice build, youve been at this game a while?, had a pic of your colourscheme on an 86 a few years ago now. Keep up the good work
An 86 is for Life, not just for Christmas |
01-01-2008, 02:57 PM
Very nice.. great looking build.
FABRICA MI DIEM, PVNC! |
01-06-2008, 03:46 AM
Great job,best of luck in the future
TURBO'D HACHI |
03-23-2008, 11:20 PM
And just to prove that ae86's are not slow on tarmac here are the results from a recent 9km tarmac hillclimb , loosing the final run due to fuel surge from trying to run too light a fuel load!!
http://www.hamiltoncarclub.org.nz/Result...esults.pdf The conditions changed from damp to dry from the bottom of the hill to the top. Who said 4wd was fast??? |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,931 |
09-09-2022 09:07 PM Last Post: Vaptor |
OST-050 - a VERY special build | oldeskewltoy | 49 | 35,757 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
d3nso's little AE86 N2 build | d3nso | 27 | 34,416 |
11-13-2017 11:42 AM Last Post: mad.matt |
Sum_Fing_Wong's Project Levin | Sum_fing_wong | 37 | 54,087 |
08-23-2016 01:29 PM Last Post: Ivan141 |
nzae86's TRD ae86 N2 Race Car Project 2, | nzae86 | 577 | 1,175,180 |
04-28-2016 11:16 AM Last Post: Super86 |
