AE86 weights list
03-26-2013, 08:13 PM
AE86 weights list
Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-26-2013, 08:23 PM
AE86 weights list
NoHachi Wrote:Header (OEM, TRD etc) Source: Google Stock: 12kg GReedy Titanium header: 2.4kg Now some weight specs from Hachiroku.net (roundet some weights): Engine: 4age alternator: 3.9kg 4age trd engine rubber mounts: 0.7kg 4age oil cooler: 0.7kg Heater fan: 2.2kg Suspension: GT-S hubs with bolts,without nuts and wheel bearings: 2.1kg each Outer tierods: 0.4kg each TRD/TTE lower front control arm ( extended 15mm and boxed): 1.7kg each Stock tension rod with bushing: 1.1kg each Tension rod bracket: 16kg each Upper 4link arms: 1.1kg each Lower 4link arms: 1.2kg each Front ventilated discs 231mm: 3.7kg each Bracket for front caliper: 0.7kg each Rear discs: 3kg each Rear calipers without pads: 3kg each Interior: Back carpet: 2.4kg Front carpet: 5.0kg Wiring harness for the whole vehicle+instument cluster+wiper motor: 12kg Dash board: 3.2kg Seats front: 20kg each Backseat: 13.2 kg Seat belt stuf (inc brackes, bolts, ect): 3.2kg Aircon unit (everything) 13.2kg Back door cards: 1.8kg Front door cards: 4kg Head lining (inc plistic trim ect): 3.6kg Screw's bolts and clips: 7kg Bracing out of doors inc. winder stuf: 6.4kg Number plate lights and clips: 1kg Parcil tray and trim inc. sun visor: 2.8kg lightend loom and unused wire: 6.2kg Bracing out of bonet 4.4kg Hing's of boot: 2kg Back window 7.6 Door glass: 3.8kg each Back side glass: 4.4kg This thread keeps me searching for partweights nonstop... ![]() |
03-26-2013, 10:11 PM
AE86 weights list
i did some weighting on parts i had outside of the car
european coupe ae86 window parts: Lexan kit from gp4 rear windows left: 1 kg a piece front windows from the door with sliders and kit:2,4kg for a piece rear window:3,1kg oem window parts rear windows left: 2,15 kg a piece front windows door ![]() rear window:7,8kg front:11,9kg other seat:17,8kg a piece trunk with oem spoiler:11,1 kg door wityh everything no power windows:27,8kg hood with celica dynamic weird thingy ![]() front bumper with brackets:7,3kg rear bumper with brackets: 6,8kg front fender:2,8kg sunroof parts almost all:8,5kg sunroof interior part under the roof(gehemelte):400gr dashboard just the back with the vent parts and clock surrounding:3,1kg T50:30,5kg the mcnsport ae86 is under 800kg |
04-18-2013, 02:15 PM
AE86 weights list
NoHachi are those OEM parst from European version ?
11-23-2013, 11:37 PM
AE86 weights list
my door is 26kg with all. naked stock door-14kg. fibreglass-5.5/6kg is full naked. t50-26kg.
trueno bonnet-14kg .rear cover of 2doors trueno- 8kg. my new altezzas az6 is 42kg. |
12-21-2013, 03:33 PM
AE86 weights list
Wel i finally got my car on the scale to days ago... whit original engine and roll cage.... 807 kg.....
http:// |
12-22-2013, 03:40 PM
AE86 weights list
Thats a really nice result.. I see lexan windows, what other weightsavings have you done?
12-23-2013, 07:43 AM
AE86 weights list
do modified stuff weights interest anybody?
h100/pajero axle with lsd and halfshafts assembled: 71kg (oem ae86: 57) |
12-23-2013, 11:38 AM
AE86 weights list
Lajoosh Wrote:do modified stuff weights interest anybody?Definately interest me ![]() An analogue brain in a digital World |
12-23-2013, 12:42 PM
AE86 weights list
Lajoosh Wrote:do modified stuff weights interest anybody? I was just looking for this information last night ![]() |
