Adjusting handbrakes (+ back up light with pictures)
05-16-2005, 02:09 PM
I have same problem with reverse light, i have a shortcircuit somewhere, have tried new switch, didn't work. didn't have time to fix yet, but you don't need for MOT/APK , not sure for RDW though.
Disclaimer: Any errors in spelling, tact, or fact are transmission errors.
05-16-2005, 02:12 PM
The handbrake is working, thank you guys! Smile
Now only the back up lights, I think i'm missing the cable between the lights and the gearbox. And a picture of the suspected cable.
05-16-2005, 02:56 PM
toypower Wrote:The handbrake is working, thank you guys! Smile
not for the handbrake - these cables are not connected on my car either.
K
05-16-2005, 03:10 PM
toypower Wrote:Now only the back up lights, I think i'm missing the cable between the lights and the gearbox.
Right in the spot! Smile I have exactly the same problem and have been discussing it with friends for some time! I checked everything else - fuses, light bulbs, boxes when i finally firgured it out - no cable! Smile Could someone (with a present cable) take some photos and describe it. I need a raplcement!
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
05-16-2005, 07:40 PM
cj, I made some pictures of the sensor. It's located under the car on the left side of the gearbox (small part).
I'm glad that I managed the lighting so I can travel tomorrow to the RDW to get a registration for the car.
The cables are original red with a black line in it. Succes CJ! Thumbs up!
The red cable is found if you follow the engine wires. The engine wires run from near the vacuummeter
  Can you convert your 86 back too the original state? gh0st 7 4,966 04-25-2022 04:25 PM
Last Post: gh0st
  Detailed LHD engine bay pictures Bean 0 3,742 08-05-2018 04:09 PM
  back camber of CBY roiz86 5 10,443 03-24-2013 02:00 PM
Last Post: roiz86
  Boost Gauge help with Pictures Okami 42 45,847 10-17-2011 05:34 PM
Last Post: Okami
  e-brake adjusting mechanism not working! fax0815 3 5,619 09-06-2011 09:16 PM
Last Post: fax0815
