Fitting camber plates on shocks with odd threaded nuts
10-16-2007, 07:24 PM
*edit* split from AEU86 shop thread after question of fitting Tein camber plates with KONI. KONI has a different threading for the nut then the standard nut that comes with the Tein camber plates (standard AE86 shock thread) so you either need to get a special nut made, or do something else which we're discussing here.*/edit*
Hi Werz, Yes and no ![]() They fit just fine but from what I've been told by Oldskull is that the standard nut that is delivered with the Tein has threading that does not fit the KONI shock. I have to try some day to find out which shocks do fit the Tein standard nut and which don't. I'm still supposed to go past Oldskull to try an set of nuts I have lying around that should fit KONI and the Teins and make the install complete. These are the nuts Jamie made for me for the HTS's. I did hear from another guy that fit the Teins that used the nut that came with the KONI's together with a bush that fit the Teins or whatever camber plates he installed. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-16-2007, 09:51 PM
You could probably get away with using a metal bush and separate nut, you only need about 1,5 - 2 cm's, there is probably more than enough thread on the koni's to do this safely... Damn koni and their 1.25 thread pitch...I've had enough problems finding nuts to fit them as well. (From a safety/quality point of view, the finer thread does seem less likely to shake loose by vibration.
10-16-2007, 10:54 PM
i just use the std. nut Koni deliverd with my koni shocks, works fine too
![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-16-2007, 11:32 PM
The Doctor Wrote:i just use the std. nut Koni deliverd with my koni shocks, works fine too Not applicable for camber plates - by design. |
10-17-2007, 12:16 AM
well, untill i find some nuts which fit, i'm using them
10-17-2007, 12:28 AM
Doc, camber plates needs deep-type of nuts.
Do you use camber plates + plain type of nuts ? If yes - any photos/description of setup 9brand of shocks and plates) ? |
10-17-2007, 12:35 AM
i use Cusco Camberplates with Koni shocks.
And i just used the stock Koni nut, i know i should use the deep-type nut, but i hadn't got them while i was installing the camberplates (and running late for an alignment appointment, 4 hours before i went to a weekend-trip to the UK ![]() ![]() "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-17-2007, 12:50 AM
Cool Doc, thanks !
10-17-2007, 12:53 AM
what is cool about using the wrong nuts?
![]() Or did you think it was not fisically possible? "It's all about the heart, the people who focus on parts, turbo's and all that stuff...they're just losers." -Shinji Minowa |
10-17-2007, 01:55 AM
No, it's cool that it's possible in your particular application
![]() I prefer to keep the things simple - when possible. |
Fitting Air Con (No PS) to LHD AE86 | pack | 7 | 4,625 |
01-07-2024 11:36 AM Last Post: CCB |
Fitting Fibreglass Kouki Lip? | chrisae86 | 3 | 2,342 |
02-25-2022 08:14 PM Last Post: chrisae86 |
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,719 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 21,457 |
Fitting driftworks CS2 coilovers | bozu | 2 | 4,962 |
05-30-2017 10:50 AM Last Post: bozu |
