Jimmi's Trackday car
04-21-2009, 02:13 PM
Well I'm converting my 3 door AE86 into a trackday car. I'm not a good racecardriver (I'm too damn carefull), but I think its funny to build cars. I have done a few engine conversions on FWD Toyotas and done a few engine rebuilding and tune ups. I'm educatet Toyota car mechanic and have worked with Toyota for 10 years now.
This will be my first actually racecar build and I try to do it all by myshelf. The basic car was importet from Switzerland, as the Danish one are too rusty. Unfortunally this one also have a bit hidden rust, but not too much. In fact, this car will not be a 100% racecar because it should be able to run on the streets, as the trackday rules i Denmark said, that the cars have to run with numberplates and therefore has to be streetlegal. The car have to pass MOT test every 2 years, so I have to build it, so I can change it in a few time :wink: The original idea was to build it, so I can make it 100% stock again in a few days, but this will be too difficult so I change the plan. I will also try to build the car after the FIA and DASU (Danish Automobile Sports Union) rules, so the car can be converted to a 100% racecar or rallycar some day. With all that in mind, I can start to make it happen ![]() ![]() ![]() ![]() ![]() ![]() ![]() I did't have any dry ice, so I took some regular free snow. Well the tempereture in the workshop was only 1,5 degrees celcius. ![]() I only used this tool and it took me about 4 hours. ![]() I removed almost 20kg. ![]() ![]() ![]() ![]() ![]() Some of the hidden rust ![]() ![]() Took this part from a EE80 Corolla, fits perfectly, but the corners dont. ![]() ![]() ![]() I borrow this piece of tool. And spotwelded the roof, dorholes and the right rear fender. ![]() ![]() I also spotwelded it a bit ![]() ![]() ![]() ![]() ![]() ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
04-21-2009, 02:37 PM
Very nice work.
![]() Always remember: Rev it till it blows, then back off a bit... Zenkis - Orange, Red/Black, Silver/Black, Maroon/Blue Koukis - Red, Silver/Gray, |
Cool project!
Good luck ![]() |
04-21-2009, 02:40 PM
Phase 2, allmost 8 months without doing anything. It have also been winter and I have no heat in my workshop.
I hammered up the fenders and sealed it. ![]() This is with 7x15" ET -5, and the wheel don't hit. The spring stop is removed. I think I can run with a 7½" or 8" ET 15 with the car not so low. ![]() It was time to get it up ![]() ![]() I have to repair the old parts, because U can not buy them anymore. ![]() ![]() ![]() ![]() I will try to make a new frame here so the lower 4 links can be more stiff. ![]() ![]() Its done in a regular 0,8-0,9mm sheet metal and bended in hand between to pieces of solid metal. ![]() The finish part ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
04-21-2009, 03:49 PM
Here's some of the stuff I have collectet.
TODA 4-2-1 header. It only fits RHD and my car is a LHD, so I have to make a few adjustment to the steering rack. ![]() Whitelines, pretty rare here in Denmark ![]() Sparco stuff ![]() ![]() ![]() Quaife quick steering rack ![]() TODA 200mm upratet clutch ![]() Slightly used TEIN suspension. ![]() 18L safetytank ![]() KaaZ 2way LSD ![]() ![]() Reinforced enginemounts, and it also lower the engine 10mm ![]() TRD Carillo Formula Atlantic con rods with 19mm pin ![]() Here's my new baby, fully portet and flow testet smallport head. There is maked room for high compression pistons. ![]() The porting and flowing is done by a motorcycle tuner and he actually put material on around the valveguides and the guides are changed to a thinner type. The valves are polished and I think he did a 3 angle valvejob also. The guy I bought it from, used it on his rallycar. He claimed that the engine produced 196hp and 190nm @ crank with custom made 288' duration and 8,0mm lift cams with stock buckets and springs. ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
04-21-2009, 05:53 PM
Jimmi The Kid Wrote:This looks very nice! I wish I would've thought of doing the ones on my car the same way. BTW, I used to have a RWD Starlet with a 4K, 300deg cam, bike carbs, etc. One of the lower link brackets got torn off the car on a hard acceleration. ![]() |
03-03-2012, 09:55 PM
Its bin a sloooooow build, but now I got some news
![]() Sandblastet the body ![]() Painted with 2K Epoxy primer ![]() ![]() Made some FPR copies ![]() ![]() Ready for paint ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
03-03-2012, 11:58 PM
Made some FPR copies --->im intersted for a set....
![]() rear wheels cant be with this ofset mate...-5 offset with spacers maybe?? ![]() |
03-04-2012, 10:51 AM
Petros AE86 Wrote:Made some FPR copies --->im intersted for a set.... I can't not promise I can make more of them, but I have though about it. Yes, I think your right about the offset, but we will see ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
03-04-2012, 08:46 PM
The car back from the paintshop
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
Project: My new trackday toy (56k beware!) | Morten | 88 | 84,271 |
02-25-2010 01:44 PM Last Post: Morten |
MCNSPORT.com AE86 4ag Trackday project! | MCNSPORT.com | 5 | 16,607 |
09-17-2009 08:26 PM Last Post: MCNSPORT.com |
MCNSPORT.com AE86 4ag Trackday project! | MCNSPORT.com | 4 | 9,785 |
06-01-2009 10:09 PM Last Post: robokill |
