My 86 dynoed 148 hp on wednesday 10 2013
07-12-2013, 01:23 PM
hello,
I have just dynoed my car to see how was my rebuilt and to set the timing of my camshaft. That might interest someone. the set up is: i paste my thread from 4AGE results makkuro Wrote:makkuro Wrote:What cam timing will you recommend formy set up? Also project d Quote:If I can add few things up about makkuro's setup. my toyota is fantastic |
07-14-2013, 12:52 AM
![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-31-2013, 01:01 PM
What percentage of transmission loss do you boys get through your prop?
07-31-2013, 03:10 PM
Alex170984 Wrote:What percentage of transmission loss do you boys get through your prop?9% |
07-31-2013, 04:52 PM
How is that possible, when the MR2 is rated at around 15% and the engine is pretty much over the rear wheels
07-31-2013, 05:26 PM
That does sound very conservative for an FR car. None the less.. 135 at the wheels is nothing to sneeze at.
07-31-2013, 06:10 PM
Project D Wrote:Alex170984 Wrote:What percentage of transmission loss do you boys get through your prop?9% hmmmm... this is an age old problem... there is no set figure to RELIABLY determine whp from hp. please read(English).... http://www.modified.com/tech/modp-1005-d...index.html As a basic rule (drivetrain loss)... longitudinal USUALLY use 15%-20%, transverse USUALLY use 10%-15%, and finally awd USUALLY 20%-30% Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-09-2013, 10:04 AM
i got this number when i asked the person who operated the dyno.
08-09-2013, 11:14 AM
Isn't the Transmission loss is calculated when the dynoguys accelerate and let off (many time) before the real WOT pull? :roll:
SR Team BURN THE RUBER NOT YOUR SOUL! |
