nzae86's AE86 Levin Tarmac rally car build Project 1
01-01-2008, 06:54 AM
I thought I would share one of my project builds that I started after destroying my Rally car on tarmac. I managed to salvage the engine , gearbox, and diff center and front brakes, the rest went to the dump!The seats broke , the dash was destroyed, it was easier to start again!
![]() After finding another good shell my panel beater cut and butt welded any areas of rust to end with a rust free body to start building a new cage into, all the fabrication work i have done myself. ![]() ![]() The shell was then sent in and media blasted back to bare metal, the sprayed with PPG DP40 etch primer ![]() The cage did it's job ok last time but I added a bit more to it for the new car ![]() The shell then went to the painters to have the top coats sprayed in a oven |
01-01-2008, 07:08 AM
While the shell was away for paint I rebuilt all the other components, sand blasting everything and repainting, i also thoght it was time for a new engine as well , the other needed pulling apart to check for oil starvation while end for ending down the road, so a bit more power was added with new pistons and balanced bottom end.
![]() All new bilstien suspension was fitted and the springs were replaced with TRD. ![]() After building a new fuel system for the car I had just finished when Motorsport New Zealand changed the rules on surge tanks and fuel pumps inside the car, so i had to redesign how it fitted and mounted it all in a sealed box ![]() |
01-01-2008, 07:24 AM
nzae86's AE86 Levin Tarmac rally car build Project 1 | |||
01-01-2008, 07:35 AM
01-01-2008, 07:51 AM
And for the finished article in action !!
One of it's first events, just to get it dirty ! at a rallysprint in the rain ![]() A small video, suffering from a nervous driver and very slippery conditions http://www.youtube.com/watch?v=b_lD1ooVwqU and another after passing the GT4 Celica http://www.youtube.com/watch?v=bgusB5tF3M8 Tarmac rally in New Zealand ![]() At a recent trackday enjoying the sunshine ![]() I am now running the car on 15 inch wheels and it suits the car very well, the rims are from a Dastun 240RS rally car , if anyone knows where I can find some more of these 15 x 7 let me know And at a recent Tarmac hillclimb, those Dunlops are fantasic, you can push them to the limit and they still hang on ! ![]() And yet another Tarmac rally in the rain !! Finished 16th O/A won 1400 - 1800cc class by over 2 minutes , take that you Honda's !!!! ![]() |
01-01-2008, 09:30 AM
thats sick... i luv 86 rally cars
![]() how come u decide to use struts and springs instead of coilvoers?? and what brakes are u using??? |
01-01-2008, 12:25 PM
Very nice build, youve been at this game a while?, had a pic of your colourscheme on an 86 a few years ago now. Keep up the good work
![]() An 86 is for Life, not just for Christmas |
01-01-2008, 02:57 PM
Very nice.. great looking build.
01-06-2008, 03:46 AM
Great job,best of luck in the future
TURBO'D HACHI |
03-23-2008, 11:20 PM
And just to prove that ae86's are not slow on tarmac here are the results from a recent 9km tarmac hillclimb , loosing the final run due to fuel surge from trying to run too light a fuel load!!
http://www.hamiltoncarclub.org.nz/Result...esults.pdf The conditions changed from damp to dry from the bottom of the hill to the top. Who said 4wd was fast??? |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 3,364 |
OST-050 - a VERY special build | oldeskewltoy | 49 | 38,335 |
01-05-2019 07:03 PM Last Post: oldeskewltoy |
d3nso's little AE86 N2 build | d3nso | 27 | 36,064 |
11-13-2017 11:42 AM Last Post: mad.matt |
Sum_Fing_Wong's Project Levin | Sum_fing_wong | 37 | 55,940 |
08-23-2016 01:29 PM Last Post: Ivan141 |
nzae86's TRD ae86 N2 Race Car Project 2, | nzae86 | 577 | 1,205,723 |
04-28-2016 11:16 AM Last Post: Super86 |
