1/8 BSPT adapter for oil pressure sensor
06-14-2013, 07:56 PM
So, I bought a oil pressure switch from an AE92 to fit Oil-P warning light. It's also 1/8BSPT as the original sensor in the AE86.
Since I want to keep the original sensor also,I wanted to buy a T piece with 1x male 2x female 1/8 bspt. But it seems impossible to find it. Anyone knows where to buy it? Or, - Can I fit 1/8 BSP onto BSPT? Is the thread in the Engine BSP or BSPT? I could find Y piece with 3x 1/8 BSP. - Many T pieces are 1/8BSPT male and 1/8BSP + 1/8 NPT female. But than I can not find a adapter from 1/8NPT to 1/8 BSPT. Any help/advice is welcome. Thanks already. |
06-14-2013, 10:53 PM
Do not put those straight to the block, because it could crack easily.
Go to the hydraulic shop and ask them to make you a 30-40cm long teflon hose with male ends. Put that in the block. Then 3xfemale T-piece and put it next to the hose and put sensors to it.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
06-15-2013, 10:01 AM
That's looks good.
And indeed two sensors straight on the block might be to heavy and crack. I will copy your layout, with you permission :wink: Than one question I have: The female side is PSB or also BSPT? (T piece) If I use BSP it will seal on the BSPT male by itself? Thanks a lot. |
06-15-2013, 12:34 PM
Go ahead, I have copy that also :wink:
All parts a bought in hydraulic shop. I think that T-piece is a BSPT "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
| map sensor cheating? | fdsjakl890 | 8 | 1,930 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| sharing knowledge - RX7 brake adapter | aussiefan | 5 | 13,270 |
04-18-2025 05:21 PM Last Post: Gintrapper |
| Lambda sensor wiring | sam3007 | 10 | 7,192 |
| Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 24,315 |
| Oil Pressure Query | Alex170984 | 2 | 6,149 |
12-11-2014 01:25 AM Last Post: Alex170984 |
