15" wheels
02-24-2015, 07:32 PM
15" wheels
Does anyone know of a standard car fitment 15" wheel that will fit an AE86 ?
I don't want to go to the expense of after market wheels and I have tried Nissan S13 rims but they needed spacers on the front to fit.
Some people have used 1.9 205 GTi (ET18 offset) wheels on Escorts and as a last resort I'm prepared to re-drill the hubs to fit these if necessary.
02-24-2015, 07:47 PM
15" wheels
I've heard that Mitsubishi wheels might fit but never tried that myself.
Daily Beater: Civic EG5
Work in progress Car: AE86
02-24-2015, 11:06 PM (This post was last modified: 02-24-2015 11:07 PM by banpei.)
15" wheels
Celica Supra 15 inch will fit nicely. Wink
But some say they are not the most desirable type... Hypocryte
[Image: AEU86 AE86 - 15" wheels]
02-24-2015, 11:48 PM
15" wheels
(02-24-2015 11:06 PM)banpei Wrote:  Celica Supra 15 inch will fit nicely. Wink
I know these are quite common in 14s but have never seen a set for sale in 15"
02-25-2015, 04:35 PM (This post was last modified: 02-25-2015 04:38 PM by Uzelac.)
15" wheels
Mitsubishi's have larger center bore 67.1 AFAIK.
Nissan has 66.1
Many Civics ran 4x114 around those years, 15 also, but they CB is 64.1.
Volvo and Saab used 4x114 10-20+ years ago
AE86 runs 60.1
I think Suzuki Swifts from '90ties used same CB. But not sure about offset.
Consider that most FWD cars used 35-45 offset. Swift is not the case, Suzuki made them for "rwd like" offset.
02-25-2015, 10:55 PM
15" wheels
(02-24-2015 11:48 PM)totta Crolla Wrote:  I know these are quite common in 14s but have never seen a set for sale in 15"
That's because nobody keeps them and sends them to the scrapyard. Wink
More seriously: they have been sold in smaller quantities as the P-Type (performance) Celica Supra was the one with the 14 inch and was sold with these throughout the production run. While the L-Type (luxury) switched from 14 inch pizzacutters in 1985 to 15 inch Celica Supra rims. So naturally they are more scarce. Still: they are less wanted than the 14 inch as they are 1 inch thinner in width and have a less desirable offset.
03-01-2015, 12:35 PM
15" wheels
Further to this does anyone know what the largest diameter tyre that can be used ?
I'm entering a series of particularly 'rough' rallies and I need as much ground clearance as possible.
The suspension is currently riding about 10mm higher than stock.
03-02-2015, 08:16 AM
15" wheels
(03-01-2015 12:35 PM)totta Crolla Wrote:  Further to this does anyone know what the largest diameter tyre that can be used ?
That pretty much depends on your suspension setup (actual travel you get under load etc...) - also I'm not sure how many different tire sizes you can get (assuming you use some 'special' gravel tires) might be easier to go from there...
03-02-2015, 11:39 AM (This post was last modified: 03-02-2015 01:24 PM by Uzelac.)
15" wheels
205/50 R15 on stock suspension, that's 586mm in circumference.
For dirt rally, i presume you will go 195 or narrower, but i guess circumference cann't go much above 600mm.
03-02-2015, 12:25 PM
15" wheels
Thanks Guys, tyres will be as narrow as possible and 185/65/15 or 175/70/15 both come in at 630mm diameter.
I can raise the suspension a further 15mm if required.
  7" rims or 8" rims? Lauren 7 9,215 05-13-2012 06:04 PM
Last Post: Lauren
  why do you use "roll center ajuster"? leckter 15 19,629 02-07-2012 07:04 PM
  Lets play "Guess that sound!" aka diff problems Apolan 6 7,774 08-28-2010 01:19 AM
Last Post: Apolan
  Green "red-top" injectors - high/low impedance? harkes 3 5,238 06-17-2009 12:53 PM
Last Post: harkes
  suspension / coiloverset up -> ?? Good / "best" Gtsi-R 5 5,830 10-28-2008 11:02 PM
Last Post: The Doctor
