16V/20V pistons
02-21-2007, 11:27 PM
16V/20V pistons
Hi,
Does anyone know, will 20V pistons work with 16V head?
Cheers!
IF Carlsberg made an AE86, then it would be propably the best car in the world...
02-21-2007, 11:29 PM
16V/20V pistons
uhmm..
no, the valve reliefs are all wrong
02-22-2007, 01:48 AM
16V/20V pistons
depends on what you mean by work.... they can be used... but if the timing belt breaks the engine is no longer non interference... Also the 20V pistons can develop hot spots because the valve reliefs are so close to the pistons edge, but in all but the most extreme conditions this isn't a significant point
Dan -
02-22-2007, 11:11 AM
16V/20V pistons
I believe Mux mentioned this somewhere, and please don't quote me on it, but it went about how the pistons are perfectly suitable, but the crown does not have the perfect profile for the job. It is non-interference for the most part, but the most dangerous aspect was already mentioned - if a camgear skips a tooth you'll be meeting pistons and valves and nothing good ever cam out of that...
02-22-2007, 11:23 AM
16V/20V pistons
Domi, wasn't me I think.. I know very little about engine tuning on this level Big Grin
02-22-2007, 12:05 PM
16V/20V pistons
I'm so bad at searching forums, i can't find it =(
Anyway, one of the knowledgeable people made the comment about the valve pockets on the piston crown - they do differ and that is the main difference. Anyway there's a good enough chance you can find aftermarket pistons for the 16v that'd be more expensive, but worth the wallet-stretch...
02-22-2007, 06:08 PM
16V/20V pistons
The question is vague.... BUT I'm using a 20V silvertop short block in my AE86... I refitted 16V OEM high compression pistons. The piston wrist pin is the same from the 20V and the 16V high comp, so it(16V high comp piston) just fits with no issues.
Dan -
02-22-2007, 08:22 PM
16V/20V pistons
Thanks for UR opinions. I know that there would be a collision when timing belt breaks, but if You want to have a comp. ratio 11:1, that doesn't metter which pistons you're running - even aftermarket forged items.
What about knocking? Do You think that capacity between piston&head won't be to small?
Cheers!
02-22-2007, 08:44 PM
16V/20V pistons
Why dont you just get ae92 high comp pistons (10.9:1) and just get the rest from milling the engine/head or a thinner headgasket? You can get the pistons for under 300 euro's these days, dunno about 20v pistons, but I daresay the 16v pistons will do the job better combined with a 16v head.
02-23-2007, 01:37 AM
16V/20V pistons
16V pistons are ok but high comp. are 10:1 (low comp. 9.6:1). Even with 0,5mm head gasket, there will be ca.10.6:1. But maybe You're right. Why do risky experiments.
Are 20V rings interchangeable with 16V high comp rings? I'm asking 'cause I've got brand new genuine STD bore set for 20V. It would be nice to use them.
Cheers!
  82mm Stock compression Pistons apardal 4 2,894 11-24-2021 04:26 PM
Last Post: apardal
  Small Port 10.3 Pistons Alex170984 1 4,381 10-25-2016 09:18 PM
  How to install 20V ITB on 16V head Mr.komp 7 11,850 12-28-2015 05:35 PM
Last Post: pack
  16V ECU pinout on 20v swap pack 2 5,526 06-12-2015 01:22 AM
Last Post: pack
  20v block with 16v head and internals possible? ditn 3 7,103 08-12-2014 09:19 PM
Last Post: ditn
