20v block with 16v head and internals possible?
08-12-2014, 05:36 PM (This post was last modified: 08-12-2014 05:37 PM by ditn.)
Got a question Smile
Is it possible to use a 20v block from a blacktop with 16v internals head and externals?
Reason is because i have parts left from previous 16v with worn block and a good 20v block.
08-12-2014, 05:42 PM
Should work fine its the same block as i remember right Wink
Daily Beater: Civic EG5
Work in progress Car: AE86
08-12-2014, 06:29 PM (This post was last modified: 08-12-2014 06:33 PM by oldeskewltoy.)
(08-12-2014 05:36 PM)ditn Wrote:  Got a question Smile
1) 16V head - use 16V gasket kit.
2) If you retain 20V pistons = engine becomes an interference engine (means if the timing belt breaks, you break valves and pistons).
2a) If you retain 20V pistons - compression ratio will go up... by how much... depends on what pistons you had in the old block, and which 20V pistons are in your 20V block.
3) You will need to use the 20V oil pan, the blocks oil pan mounting flange is different between 20V and 16V, the 20V pan has a "notch" in it. For your oil cooler (if equipped) you can either drill and mount a return... OR you can buy an oil pan from a AE95 All-Trac Corolla. They have a similar oil pan, but it has an oil cooler drain welded in
Dan -
08-12-2014, 09:19 PM
thanks for the info Smile
1)noted
2)wont be using any parts from 20v except for the shell
crank,pistons,... will be 16v
3)noted
  20v BT Head filh 4 486 03-11-2025 09:51 PM
Last Post: oldeskewltoy
  Question about 4AG 20v Engine Block CHACAMAN 1 1,816 06-10-2022 05:17 PM
  4AGE block differences explained (incl. some eyecandy) Bean 46 90,438 05-05-2019 04:03 AM
Last Post: Rocker100
  BT head with ST block. CHOPKIN2 6 7,543 02-06-2018 06:27 PM
  weird gearbox part2(possible trd set a) ditn 6 7,387 01-31-2016 08:01 PM
Last Post: totta Crolla
