20V ITB - what fuel rail and injectors ?
03-09-2010, 12:47 PM
Hi
When going to 20V 4AGE ITB's, what fuel rail and injectors should to be used ?
- Standard 4AGE 16V rail and injectors
- standard rail and more cc injectors
- some other rail and injectors ?
Is there anything else which have to be replaced when changing TVIS for ITB. I'm thinking "locally", just on intake.
ECU, air sensor and other stuff are "of course"..
Thanks
03-09-2010, 01:34 PM
well injectrs depend on how much power you'll be running in the end. the 16V rail should to the trick
03-09-2010, 02:24 PM
stock fuel rail and red top injectors will do the job
If youre aiming high power output (170+) use low impedance 310cc injectors with FPR
IF Carlsberg made an AE86, then it would be propably the best car in the world...
  Trunk and fuel door cable pack 2 6,498 04-23-2018 11:01 PM
Last Post: pack
  Smallport Fuel Rail Alex170984 2 4,505 11-19-2016 08:44 PM
Last Post: Alex170984
  4A-GE 20V ITB bolt patterns kjb 7 11,801 02-27-2016 01:23 PM
Last Post: kjb
  How to install 20V ITB on 16V head Mr.komp 7 11,663 12-28-2015 05:35 PM
Last Post: pack
  Machining Pistons to run 20v head... And FCR's on a 20v? PazzaAE86 2 5,067 09-15-2013 01:08 AM
Last Post: jondee86
