Refurbishing Kouki "Glass" Grill
09-23-2014, 05:22 PM
Hi Guys,
As a fix for my grill while I source a Foglight grill that doesn't cost a butt load, does anyone have any tips/tricks for refurbishing a foggy "glass" grill?
It's also had the "Toyota" text painted and it's looking a bit naff so I'd need a paint remover that doesn't affect plastics.
Thanks in advance guys Big Grin
Matt
09-23-2014, 10:07 PM
Polish, just like you would do on the paint of your car Wink
And to remove the text just use a rubbing compound, again like on the paint. (do that before the polish, obviously)
09-24-2014, 01:19 AM
Cheers for the reply Smile
So a cutting compound like K3 etc with a increasing grit fineness and some elbow grease? Smile
09-24-2014, 08:05 AM
I don't know K3, but something like 3M Perfect It and elbow grease yes Tongue .
You could also use a buffing machine to speed up the process, but be very careful with the heat.
If your grill is very grainy you can sand it with a 800 /1000 grit sandpaper before.
09-24-2014, 09:21 AM
Or you could check out one of the kits sold for refurbishing plastic
headlight covers that have gone yellow. Most involve buffing with finer
and finer compounds, and finishing off with a "miracle" polymer polish.
Plenty of videos on utube Smile
Cheers... jondee86
09-24-2014, 10:29 AM
Thanks guys, all your replies are appreciated.
I think I'll try a cutting compound and a MOP, just keep it wet etc and go to town on it Smile
Then I'll just finish off with Autoglym Super Resin Polish and a coat of wax.
  Kouki to Zenki Levin grill conversion? Mylesmck 6 2,687 02-08-2024 10:30 AM
Last Post: r.ave
Wink Can Wing Mirror Glass be Replaced? chrisae86 1 1,330 03-05-2023 09:34 PM
  Radiator & grill support panel (Levin) FanIsHere 5 2,371 11-14-2022 10:07 PM
  European/UK vs Japanese Levin "Glass Grill" mad.matt 3 6,068 10-20-2017 02:47 PM
  Rotating grill stratosTRD 5 6,885 04-02-2013 09:49 PM
