Refurbishing Kouki "Glass" Grill
09-23-2014, 05:22 PM
Hi Guys,
As a fix for my grill while I source a Foglight grill that doesn't cost a butt load, does anyone have any tips/tricks for refurbishing a foggy "glass" grill? It's also had the "Toyota" text painted and it's looking a bit naff so I'd need a paint remover that doesn't affect plastics. Thanks in advance guys Matt |
09-23-2014, 10:07 PM
Polish, just like you would do on the paint of your car
![]() And to remove the text just use a rubbing compound, again like on the paint. (do that before the polish, obviously) |
09-24-2014, 01:19 AM
Cheers for the reply
![]() So a cutting compound like K3 etc with a increasing grit fineness and some elbow grease?
09-24-2014, 08:05 AM
I don't know K3, but something like 3M Perfect It and elbow grease yes
.You could also use a buffing machine to speed up the process, but be very careful with the heat. If your grill is very grainy you can sand it with a 800 /1000 grit sandpaper before. |
09-24-2014, 09:21 AM
Or you could check out one of the kits sold for refurbishing plastic
headlight covers that have gone yellow. Most involve buffing with finer and finer compounds, and finishing off with a "miracle" polymer polish. Plenty of videos on utube ![]() Cheers... jondee86 |
09-24-2014, 10:29 AM
Thanks guys, all your replies are appreciated.
I think I'll try a cutting compound and a MOP, just keep it wet etc and go to town on it ![]() Then I'll just finish off with Autoglym Super Resin Polish and a coat of wax. |
| Can Wing Mirror Glass be Replaced? | chrisae86 | 4 | 2,637 |
10-05-2025 11:09 PM Last Post: chrisae86 |
| Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 4,488 |
02-08-2024 10:30 AM Last Post: r.ave |
| Radiator & grill support panel (Levin) | FanIsHere | 5 | 3,721 |
11-14-2022 10:07 PM Last Post: Ivan141 |
| European/UK vs Japanese Levin "Glass Grill" | mad.matt | 3 | 7,410 |
10-20-2017 02:47 PM Last Post: mad.matt |
| Rotating grill | stratosTRD | 5 | 8,117 |
04-02-2013 09:49 PM Last Post: banpei |
