20v block with 16v head and internals possible?
08-12-2014, 05:36 PM
(This post was last modified: 08-12-2014 05:37 PM by ditn.)
Got a question
Is it possible to use a 20v block from a blacktop with 16v internals head and externals? Reason is because i have parts left from previous 16v with worn block and a good 20v block. |
08-12-2014, 05:42 PM
Should work fine its the same block as i remember right
08-12-2014, 06:29 PM
(This post was last modified: 08-12-2014 06:33 PM by oldeskewltoy.)
(08-12-2014 05:36 PM)ditn Wrote: Got a question 1) 16V head - use 16V gasket kit. 2) If you retain 20V pistons = engine becomes an interference engine (means if the timing belt breaks, you break valves and pistons). 2a) If you retain 20V pistons - compression ratio will go up... by how much... depends on what pistons you had in the old block, and which 20V pistons are in your 20V block. 3) You will need to use the 20V oil pan, the blocks oil pan mounting flange is different between 20V and 16V, the 20V pan has a "notch" in it. For your oil cooler (if equipped) you can either drill and mount a return... OR you can buy an oil pan from a AE95 All-Trac Corolla. They have a similar oil pan, but it has an oil cooler drain welded in Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
08-12-2014, 09:19 PM
thanks for the info
1)noted 2)wont be using any parts from 20v except for the shell crank,pistons,... will be 16v 3)noted |
Question about 4AG 20v Engine Block | CHACAMAN | 1 | 1,507 |
4AGE block differences explained (incl. some eyecandy) | Bean | 46 | 85,376 |
05-05-2019 04:03 AM Last Post: Rocker100 |
BT head with ST block. | CHOPKIN2 | 6 | 6,923 |
02-06-2018 06:27 PM Last Post: mad.matt |
weird gearbox part2(possible trd set a) | ditn | 6 | 6,773 |
01-31-2016 08:01 PM Last Post: totta Crolla |
How important are dowell pins on a 4age block | spill86 | 5 | 7,321 |
01-13-2016 11:19 AM Last Post: spill86 |
