Downpipe + exhaust under 102 db
09-12-2019, 07:43 PM
Hi everybody,
This time I am looking for a good exhaust setup. I want to keep my original header but the 2 - 1 pipe needs to be longer, no cat and just a damper in the rear. Go under axle or stay original? Car is track only with a KYB shortstroke damper setup. Anybody got some experience? Also not to loud.. 102 db max! Thx!! |
09-12-2019, 10:45 PM
(This post was last modified: 09-12-2019 10:49 PM by Bean.)
Depends on your budget, you could get a Martelius which would include a header or Fujitsubo they have several setups available.
Closest to your description is the Toda N1 kit, not sure if it'll meet the noise regulation though Sent from my LYA-L29 using Tapatalk AE86 ex-daily |
| I need some info about the plastic under the 2 front fender | Mattolo | 4 | 6,702 |
02-22-2010 01:28 PM Last Post: Mattolo |
| Under shim bucket kit qustion | Jimmi The Kid | 13 | 19,120 |
07-08-2009 04:04 PM Last Post: Bean |
| Bogging problems with Silvertop 4AG (BT ECU) under 3500 RPM | LAC99 | 4 | 6,194 |
06-18-2009 10:28 PM Last Post: LAC99 |
| Rear travel setup with Tokico HTS 102 | Uzelac | 5 | 10,643 |
05-19-2009 01:33 AM Last Post: Uzelac |
| Largest front brakes under 13" rims...? | 4000GT | 6 | 8,719 |
01-26-2009 10:51 AM Last Post: 4000GT |
