Bogging problems with Silvertop 4AG (BT ECU) under 3500 RPM
06-18-2009, 01:45 AM
I have a problem with my silvertop 4ag when it revs from idle to about 3500 RPM. I didn´t know how to describe it in english but someone just told me it´s called "bogging" (sorry for my english, by the way).
Anyway, it has a Blacktop ECU and MAP and the thing is that below 3500 RPM it has this bogging problem that I can´t get rid off. I´ve tried replacing the ECU with another BT ECU, changing the module, new wiring harness and also changed the TPS but it still does that bogging thing.
from 3500 to 8000 (according to my SAFC) it works perfectly but below that is really frustrating, specially if I give it full throttle because the engine starts knocking a little bit so I have to let go a little.
I don´t know if this helps you get a better picture but when I let go a little bit the throttle it actually revs better than at full throttle. That´s why I thought it was the TPS sensor but when I changed it, I had the same problem.
any ideas? I don´t have a oxigen sensor connected but I thought the SAFC would solve that.
thanks
06-18-2009, 05:32 AM
What does the bogging feel like.
Are you able to film it?
Kp62 - 135hp
Ae86 - 135hp
C32 Laurel - 440hp
C32 Laurel - 125hp
[Image: AEU86 AE86 - Bogging problems with Silve...r 3500 RPM]
06-18-2009, 10:20 PM
LAC99 Wrote:from 3500 to 8000 (according to my SAFC) it works
go a little.
Your engine should have a "knock" sensor, and when it detects knocking
the ECU will retard the ignition timing until the knocking goes away. Then
after a short time, it will put the ignition timing back to normal.
I think you should check you ignition timing. It should be set at 10 BTDC
with the diagnosis connector "shorted" and all accessories off. If you use
low octane gas, the problem will be worse. Try and use the best gas you
can get... 95 octane or better.
Cheers... jondee86
06-18-2009, 10:28 PM
good idea, I´ll try to film it this weekend so you get the idea
the knocking is recent... I had this bogging problem since I got the car and it didn´t knock then. Still it won´t hurt to check the ignition timing.
I´ve seen in other forums problems like mine that were solved by checking the STA wire... I´ll try that also.
I only use 97 or 98 octanes gas in this engine.
thanks guys, I´ll keep you posted with the results of this weekend tests...
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 3,136 05-26-2024 07:40 PM
Last Post: totta Crolla
  No idle below 2000 rpm rich running Steller Engineering 3 1,751 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Question about 4AG 20v Engine Block CHACAMAN 1 1,855 06-10-2022 05:17 PM
  Big wheel problems gh0st 16 9,025 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,896 08-31-2021 06:20 PM
