Starting problems 4-AGE kouki
08-29-2021, 10:23 PM
(This post was last modified: 08-29-2021 10:31 PM by Hanzo.)
Hi folks,
i recently visted a fellow AE86 owner. He is from the netherlands. He restored his AE86 with his father. They are boat builders so there are quite handy with body work. His problem is that his engine won't start. His mechanic says that the injectors are turned off by something as soon as engine tries to run. It almost starts and if it starts it immediately goes out. Engine wasn't rebuild he changed oil pan, air intake and exhaust header. The harness is stock. He check the TDC, I also uploaded a video from his ae86. Maybe somebody has an idea. AE86 Starting Thanks in Advance. |
08-30-2021, 02:38 AM
(This post was last modified: 08-30-2021 03:08 AM by Bean.)
Missing or bad injector ground most probably. The part of the wiring of the injectors has a small ground attached to it. This usually connects to the intake manifold between cylinder 1 & 2 (if I remember correctly).
AE86 ex-daily |
08-30-2021, 11:40 PM
(08-30-2021 02:38 AM)Bean Wrote: Missing or bad injector ground most probably. The part of the wiring of the injectors has a small ground attached to it. This usually connects to the intake manifold between cylinder 1 & 2 (if I remember correctly). Thank you Bean, i sended your answer back to Ruben. I think we found something related to the ground wiring of the injectores. Ruben will also register here and make a thread from his AE86 restauration. His AE86 had quite a lost of rust. |
08-31-2021, 06:20 PM
As Bean says above, just to add that it may initiaĺly be trying to start only on the cold start injector. This works when you crank the engine on the starter.
Big wheel problems | gh0st | 16 | 8,963 |
lntermittent starting | totta Crolla | 6 | 3,977 |
Problems Mintex M1155 pads | Dino86 | 9 | 9,410 |
07-04-2017 11:22 AM Last Post: totta Crolla |
JDM trueno not starting. need help! | kazi | 8 | 9,273 |
16v Bigport fuel problems | Rascal21 | 1 | 4,950 |
07-04-2015 01:00 AM Last Post: jondee86 |
