3sge from m2 in ae86
12-23-2010, 01:25 AM
can i put 3sge (gen 2) from MR2 into ae86 ? what gearbox ?
I saw people did alteza 3sge in hachi .. but i didn't find anything about mr2 3sge into ae86 Please help |
12-23-2010, 03:01 AM
its a bit difficult mod, but possible. look it up in google!
you have to put the engine in tilted to the right side by 20degrees to fit it under the hood, modify the oil pan, cut and relocate the throttle body to the front side of the induction box. you have to use a W5x series gearbpx, possibly w55, w57 or w58 and make or search and buy a custom bellhousing inbetween. also there may be some firewall space problems occur as well. |
12-23-2010, 06:54 AM
diesel corollas "*e70" serie have correct bellhouse whit w50 gearbox.. bolt on..
you need to cut and weld or put different intake to car. but 3sge fits nice to rwd corollas.. |
12-23-2010, 10:56 AM
this is relevant to my interests! plz moar!
12-23-2010, 12:00 PM
Lajoosh Wrote:this is relevant to my interests! plz moar! Vouch. plz moar ! |
12-23-2010, 10:57 PM
Also the Carina CA60 diesel (1C engine) will fit to the W bellhousing.
I found this list some time ago with our NZ friends: 1C 2C 3C 1S 2S 3S 4S 5S 1VZ 2VZ 3VZ 4VZ 5VZ 1MZ 2MZ 3MZ 1GR 2GR 3GR 4GR http://forums.toyspeed.org.nz/viewtopic.php?t=73257 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
12-23-2010, 11:54 PM
banpei Wrote:Also the Carina CA60 diesel (1C engine) will fit to the W bellhousing. ca60 gearbox can hold the power of 3sge - 3sgte ?? |
01-02-2011, 03:04 PM
there is a lot of 3sge conversion information here:
http://www.ae86drivingclub.com.au/forums...-KE-thread My website: S-86.com |
01-02-2011, 09:52 PM
Xerius Wrote:ca60 gearbox can hold the power of 3sge - 3sgte ??Depends on whether it has a W50 or W55 behind the bellhousing. BTW: found another interesting source: Quote:S to WSounds like you need to source a Hi-Ace diesel with a 1C or 2C engine and a G series gearbox. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
01-20-2011, 12:06 PM
There's a part number for the bell housing on the net somewhere you can still order them new from the dealer
- Fuzzy |
Toyota KE70 3SGE Beams Swap - Axle reliability | cke70 | 15 | 25,213 |
04-13-2014 12:49 PM Last Post: Celica RA45 |
f20c vs 3sge | Petros AE86 | 7 | 13,707 |
02-26-2012 12:29 PM Last Post: roiz86 |
put a head of Celica 2.0 GT ST162 16v (3SGE) in mine 4a-ge | Emanuelae86 | 4 | 4,918 |
10-01-2006 06:54 PM Last Post: Corey |
