4A-GE availability
09-02-2005, 10:34 AM
4A-GE availability
Terry, you can often pick up a AE82 few GT for next to nothing. Else check out the scrap yards, Fensport used to see engines for rebuilding at £75 so you should be able to get something around that price.
[Image: AEU86 AE86 - 4A-GE availability]
09-02-2005, 02:17 PM
4A-GE availability
Are there any differences between a 4A-GEs depending on where they where mounted? Like from an AE92 and AE86 and MR2 and on?
09-02-2005, 02:32 PM
4A-GE availability
The fwd ones (including mr2 as its the same layout) have mounts on the ends and things like the water pump outlets point in the wrong direction. The engine itself is the same though. The redtop TVIS engine is a direct swap as well, its only when you get to the small port that things get more complicated.
09-02-2005, 02:36 PM
4A-GE availability
I read that the later engines are stronger? anyone confirm this?
Im going to get me a 75 quid rebuild job
still no 86
________________________
09-02-2005, 03:00 PM
4A-GE availability
whats about the later 4afe engines from ae101, have they the same block and internals as an 4age?
http://www.86ers.org
