4A-GE piston rings
11-17-2012, 05:33 PM
4A-GE piston rings
Hi,
I bought new piston ring set and they are like photo1. My old rings are like these photo 2. Which ones are proper? Engine is blue top 1985 year. Can someone take a photo of orginal 4age piston rings?
Sory for my bad english Tongue
11-17-2012, 11:42 PM
4A-GE piston rings
I can't be sure...
BUT... is the top ring thinner/thicker?
earlier engines use 1.5mm thick rings for both compression rings, later types use 1.2mm thick top rings
Just because you have an early car does not mean someone hasn't already changed something.
Dan -
11-21-2012, 12:16 AM
4A-GE piston rings
Something wrong is with my account. I can't log in (or am I banned?) Nevermind. New set is 1.5x1.5x2.8 and I think they are OK. Pistons are bluetop hi comp (10:1? little dome at top). Top ring hole in the piston is wider than middle so I think 1.2x1.5x2.8 aren't for that pistons.
11-25-2012, 08:53 PM
4A-GE piston rings
PawelAE Wrote:Something wrong is with my account. I can't log in (or am I banned?) Nevermind. New set is 1.5x1.5x2.8 and I think they are OK. Pistons are bluetop hi comp (10:1? little dome at top). Top ring hole in the piston is wider than middle so I think 1.2x1.5x2.8 aren't for that pistons.
You are correct. 10 to 1 pistons use 1.5mm thick rings for both top and 2nd compression rings, the 1990+ high comp piston uses 1.2mm top ring with a 1.5mm 2nd ring
Dan -
  Piston ID kazi 5 5,512 08-11-2019 03:34 PM
Last Post: totta Crolla
  86mm piston wizards... fantapants 6 6,157 05-30-2017 02:36 PM
Last Post: jdm86gtz
  Piston Identification Alex170984 3 5,352 05-17-2016 12:47 PM
Last Post: Alex170984
  Piston availability totta Crolla 3 5,508 09-03-2015 09:32 PM
  which piston is this? ditn 10 12,007 07-04-2014 03:18 PM
