cluster conversion
07-31-2008, 03:43 PM
cluster conversion
i have a 86 kouki trueno with the dials in km/h, i have found a set of uk clocks and am wondering is it a straight with the wiring.
THE CLOCKS I HAVE
[Image: AEU86 AE86 - cluster conversion]
THE CLOCKS I WANT
http://cgi.ebay.co.uk/TOYOTA-COROLLA-AE8...0281009774
any help much appreciated
The world without TOYOTAs, cant imagine it.
08-01-2008, 05:57 AM
cluster conversion
Should have all the same wires. I doubt the plugs would have changed from pre- to post-facelift, but I can't confirm this.
On another note, where are you located, I would consider taking your old one off your hands. If you're in the UK my brother is in London.
Chris
08-01-2008, 11:26 AM
cluster conversion
The wiring is the same between zenki and kouki, so no problem there...
I did swap from zenki to kouki cluster in my trueno and found that the speed indication was off about 5%. This is probably due to it being calibrated for the slightly larger stock wheels delivered with the kouki EU model.
08-05-2008, 06:26 AM
cluster conversion
Yeah not as easy as you think. Thank god there is a speed signal converter inside the digital cluster though.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
05-13-2009, 01:16 AM
cluster conversion
Speed signal converter ?
Calibration possible or just km/h and mph ?
thanks
  20v Blacktop conversion.... Mylesmck 0 834 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 3,502 02-08-2024 10:30 AM
Last Post: r.ave
  EUDM gauge cluster banpei 22 7,245 08-15-2023 10:48 PM
  EUDM cluster revelations banpei 1 1,808 06-23-2023 09:11 AM
Last Post: r.ave
  AFM to Map Conversion ps13michi 3 4,260 01-06-2022 10:34 AM
Last Post: ps13michi
