4AGE 16v RWD Bigport Diagnostics Plug?
11-15-2014, 05:17 PM
Hi again!
Cant find the Diagnostics Box on the 16v harness (Zenki) so I`m assuming one of the many left-over plugs dangling from the engine harness close to the firewall is the diagnostics plug that needs to be shorted. Anyone know which one? Can`t get my ignition timing straight without getting engine into diagnostics mode, right now I get pinging noise whenever touching the gas.. 1x AE86 84` Zenki Coupè Levin 4A-GE 20v 1x AE86 83' Zenki Coupe Levin 4A-GE 16v 1x TA60 82' Sedan 2T 8V 1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v |
11-15-2014, 05:23 PM
4AGE 16v RWD Bigport Diagnostics Plug? | |||
11-15-2014, 09:31 PM
You can short the two pins directly on the ECU if you can't find the box or if it's been cut off
AE86 ex-daily |
Ignition switch plug and wires | Blaze0010 | 3 | 612 |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,388 |
Cusco Powerball Headers on a NA 4AGE 16V? | JDMitch | 11 | 21,778 |
05-01-2021 10:09 PM Last Post: Ivan141 |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 23,795 |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,992 |
