4AGE MEGASQUIRT BASE MAP NEEDED
07-11-2008, 09:35 PM
Hi i'm just after installing MS1 with a pc3.57, i'm using the orignal distrubutor an i've 20v itb's, high lift cams etc., just want a base map to see if i can figure it out before i bring in to the dyno.
Checked on MSi an a couple of other sites but i can' find anything
07-12-2008, 12:26 AM
o have one but it is with the high resolution code and using hybrid alpha-n.
let know .....
PS : you would have to calibrate the tps exactly as mine , or change the values on the tables ...
07-12-2008, 11:31 PM
Yeah thanks anything at all, i've nothing set
07-13-2008, 01:15 AM
map sent
keep in mind that i was using 315cc injectors and alpha-n
so check fuel and spark tables tps values , and change them accordingly to your tps values
07-13-2008, 12:22 PM
tanx qon, yeah looks good, did you use your orignal distributor?
07-13-2008, 05:16 PM
yup .... with an MAF ignitor to convert the signal from the dist to the MS
07-13-2008, 09:19 PM
Go ask on the other sites, there are a lot of guys that have the base maps available.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-14-2008, 06:42 PM
MAF ignitor ? what way did you do that?
07-15-2008, 12:39 AM
the MAF ignitor has a built in signal converter (from analog to digital) so I used that one instead of using the LM1815 on MS v2.2 or the built in converter on the v3 board.
Since it was design by toyota it might do a better job, and I have the v2.2 board , so it's a great help to have the signal already in digital.
07-15-2008, 08:28 AM
ok thanks alot qon
  AFM to Map Conversion ps13michi 3 3,263 01-06-2022 10:34 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 11,204 02-10-2020 06:39 PM
Last Post: Power_uP
  extracted freedom ecu 16v ignition map ditn 7 8,920 08-22-2016 10:01 AM
Last Post: ditn
  smallport question AFM or MAP? fax0815 5 8,351 05-17-2014 05:07 AM
Last Post: jondee86
  Tutorial : Megasquirting an European (MAP) AE86 (4age) gon 68 182,954 01-09-2014 11:23 PM
