4AGE camshafts (again)
12-11-2012, 03:08 PM
It was using a fair bit of oil before I took it off the road.
There is also evidence of oil around the intake manifold ports when I took that off last week.
12-11-2012, 04:12 PM
"I was going to get a hold of some Supertech valve guides instead of crappy ones you get pattern part gasket sets."
I guess you mean valve stem oil seals Alex ?
If so then I would use genuine Toyota ones.
12-11-2012, 04:14 PM
If you did mean valve seals I think I still have a set or even too genuine Toyota ones lying around.
AE86 ex-daily
12-11-2012, 08:52 PM
Sorry I did mean the oil seals.
12-11-2012, 09:55 PM
When it comes to the HG, even though i'm going to get it bored to 81.5mm can I still get away with a 81mm bore gasket?
Cheers
01-03-2013, 09:17 PM
I've got some photos of my bearings if anyone is interested...
One of the main ends is a bit half and half, but i'll measure the crank journal to check its in tolerance before I do anything.
Hope people like my uncomplicated numbering system lol
[Image: AEU86 AE86 - 4AGE camshafts (again)]
03-19-2013, 02:41 PM
Just a little update...
I have finally measured my deck to piston shoulder height and it is around 0.2 to 0.17mm. The block deck is in good condition so will not be decking it. I will be using a 0.0036" Cometic Metal Head Gasket
All that's needed now is to disassemble the head, take the block apart again and take it to a machinists.
I'll then try and afford the camshafts Smile
  Need help again. panda_tureno86 3 4,043 03-04-2012 06:17 PM
Last Post: panda_tureno86
  Again: LSD oil Dino86 11 12,869 09-20-2010 08:09 AM
Last Post: Project D
  What camshafts would be nice? PatrickAE86 44 39,706 08-25-2010 01:06 PM
Last Post: Uzelac
  Gear Box option - again? KD2229 11 15,350 11-27-2009 03:10 AM
Last Post: KD2229
  engine problem again overheating this time !!!! filh 11 10,903 06-08-2009 08:40 PM
Last Post: Gnugfur
