4AGE engine tuning discussion
07-01-2008, 03:41 PM
Post: #61
Sorry, doh - yeah I forgot he has the injectors placed there... So foam isn't a good idea there of course.
I don't run any filters at all and haven't had any problems thus far - and many AE86's are run like this in Japan.... Then again, the roads are good quality here and usually clean (We don't get crud lining the wheel arches & causing rot, for example) so this may be a valid factor to consider. The only time the engine bay gets a bit of dust in it is when I come off a track and into the sand, but the alloy under guard offers protection then..
The recommendations above are what was confirmed by Techno Pro Spirits when I was going through the same thinking processes as you guys... No filters and a plate beneath is the best setup if primarily what you're after is performance. Coarse mesh filters are going to give more negative than positive results TBH. I'm just sharing genuine knowledge here..
VISIT OUR NEW WEBSITES!!!!
A Tuner's Paradise
Automotive Art On Film
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 9,747 10-30-2013 11:18 PM
  Ecu ROM tuning Alex170984 4 6,959 10-13-2013 08:03 AM
Last Post: Apsogos
  Need help (4ac engine tuning) fullybuiltmiata 3 7,585 08-20-2012 09:25 PM
  co idle mixture - discussion Apsogos 12 16,249 07-13-2012 02:31 PM
Last Post: Apsogos
  GZE swap or N/A tuning Okami 14 18,346 06-14-2011 10:53 AM
Last Post: Okami
