[4AGE] ignition timing problem -> SOLVED !!
05-16-2011, 02:29 AM
If the timing does not change when you plug/unplug the diagnostic
connector, your engine is not going into diagnostic mode.
There is a list of conditions that must be met before the engine will
enter diagnostic mode. From memory....
1. Engine at normal operating temp.
2. All accessories turned off.
3. A/C turned off.
4. Idle at 850-900 rpm.
5. IDL switch in TPS closed.
6. Probably one more I've forgotten Smile yup, battery volts more than 11.
If you can't get the engine to go into diagnostic mode, as suggested
above, set the timing to 16-17 deg at idle.
Cheers... jondee86
05-16-2011, 04:01 PM
THANK YOU fax0815 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
She's back on the road !!!
Yes, the TPS was out of spec Banging head
It's crazy because I never touched this thing...
I explain :
I checked the Throttle Position Sensor, the procedure is well desdribed on the Workshop manual.
So I checked the resistances listed below using an ohmmeter and feeler blades.
0.35 mm (0.0138") IDL-E2 < 2.3 kOhms -> it means continuity and I haven't got any continuty here !!
0.59 mm (0.0232") IDL-E2 Infinity -> it means no continuity
0 mm (0") VTA-E2 0.2-0.8 kOhms
Fully open VTA-E2 3.3-10 kOhms
Any condition Vcc-E2 3-7 kOhms
I set the TPS to spec (thanks to the workshop manual again), a little tricky to do ALONE Smile
I set the ignition timing to 10° with the diag plug jumped -> NO JUMPING TDC this time !
I checked ignition timing without the diag plug jumped -> 16°
I tried the 86 on the road about 60km : EVERYTHINGs FINE !!!
Thanks again fax0815 I owe you a beer at least Smile
05-16-2011, 07:22 PM
So glad I could help. Hurray!
Check ignition again after a few more km´s and secure one of the bolts with screw locking varnish like toyota did.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-17-2011, 12:12 AM
Exactly. If the IDL switch is not closed, you cannot get the engine to
go into diagnostic mode. Good result Smile
Cheers... jondee86
05-17-2011, 12:31 AM
Wrote in my book
eg6maxx Wrote:[Image: AEU86 AE86 - [4AGE] ignition timing prob... SOLVED !!]
eg6maxx, your engine bay is so unclean and uggly Yummie!
05-17-2011, 11:48 AM
A long time ago I had a thread about my 86 here, I continued to work on my car since.
If you are interested it was featured on 7Tune (and also a French magazine), I reported mostly everythings I did on my car for 8 years on my blog, here the links :
The little feature on 7Tune:
http://www.7tune.com/reader-rides-maxime...achi-roku/
The section about my 86 on my blog (I've got some other cars) :
http://eg6maxx.over-blog.com/categorie-11389443.html
Thanks :wink:
  Ignition switch plug and wires Blaze0010 3 501 11-25-2024 12:29 PM
Last Post: Blaze0010
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,897 07-28-2022 10:48 PM
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,856 07-18-2019 03:52 PM
Last Post: oldeskewltoy
  4agze timing leon205gti 11 13,901 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,366 11-05-2016 01:34 AM
