[4AGE] ignition timing problem -> SOLVED !!
05-16-2011, 02:29 AM
If the timing does not change when you plug/unplug the diagnostic
connector, your engine is not going into diagnostic mode. There is a list of conditions that must be met before the engine will enter diagnostic mode. From memory.... 1. Engine at normal operating temp. 2. All accessories turned off. 3. A/C turned off. 4. Idle at 850-900 rpm. 5. IDL switch in TPS closed. 6. Probably one more I've forgotten ![]() If you can't get the engine to go into diagnostic mode, as suggested above, set the timing to 16-17 deg at idle. Cheers... jondee86 |
05-16-2011, 04:01 PM
THANK YOU fax0815 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
She's back on the road !!! Yes, the TPS was out of spec ![]() It's crazy because I never touched this thing... I explain : I checked the Throttle Position Sensor, the procedure is well desdribed on the Workshop manual. So I checked the resistances listed below using an ohmmeter and feeler blades. 0.35 mm (0.0138") IDL-E2 < 2.3 kOhms -> it means continuity and I haven't got any continuty here !! 0.59 mm (0.0232") IDL-E2 Infinity -> it means no continuity 0 mm (0") VTA-E2 0.2-0.8 kOhms Fully open VTA-E2 3.3-10 kOhms Any condition Vcc-E2 3-7 kOhms I set the TPS to spec (thanks to the workshop manual again), a little tricky to do ALONE ![]() I set the ignition timing to 10° with the diag plug jumped -> NO JUMPING TDC this time ! I checked ignition timing without the diag plug jumped -> 16° I tried the 86 on the road about 60km : EVERYTHINGs FINE !!! Thanks again fax0815 I owe you a beer at least ![]() |
05-16-2011, 07:22 PM
So glad I could help.
![]() Check ignition again after a few more km´s and secure one of the bolts with screw locking varnish like toyota did. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-17-2011, 12:12 AM
Exactly. If the IDL switch is not closed, you cannot get the engine to
go into diagnostic mode. Good result ![]() Cheers... jondee86 |
05-17-2011, 12:31 AM
Wrote in my book
eg6maxx Wrote: eg6maxx, your engine bay is so unclean and uggly ![]() ![]() ![]() |
05-17-2011, 11:48 AM
A long time ago I had a thread about my 86 here, I continued to work on my car since.
If you are interested it was featured on 7Tune (and also a French magazine), I reported mostly everythings I did on my car for 8 years on my blog, here the links : The little feature on 7Tune: http://www.7tune.com/reader-rides-maxime...achi-roku/ The section about my 86 on my blog (I've got some other cars) : http://eg6maxx.over-blog.com/categorie-11389443.html Thanks :wink: |
Ignition switch plug and wires | Blaze0010 | 3 | 501 |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,888 |
07-28-2022 10:48 PM Last Post: banpei |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,855 |
4agze timing | leon205gti | 11 | 13,900 |
04-07-2017 03:10 AM Last Post: jondee86 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,365 |
