4AGE with Eaton Supercharger?
12-28-2010, 01:13 AM
put post above as a sticky
12-28-2010, 11:56 AM
NoHachi Wrote:MatthewG Wrote:thats even better! cause you can "change" the hp output easier with a boostcontroller then with a (expensive) set of different pulleys... thats all true! never said that more power will have unlimited lifetime for any components or that performance will cost "nothing". but for me its clear, that the car is in top condition before any engine performance! as you guys know my car, i would never boost it until its in best technical condition. every hachi owner/performer knows the weak points of our cars! you said, that a rotrex is nothing special at low boost, thats true, but why spending money in a rotrex to have the same boostlevel? every gze owner talks about the magical "200hp limit", with a rotrex you dont have this limit! thats fact! i am also sure that a rotrex have a better hp-output then the other supercharger kinds. cheers martin |
12-28-2010, 12:49 PM
Since I am bored:
There is no "magic" hp limit. The compressor is too small. That means that it makes boost quickly, doesn't rob a lot of power and is 5kg lighter then the next model up. Until 200hp its arguably a very decent blower, above 200hp..well you're into intercooled, ecu'd, other gearbox, other driveshaft, other oil cooler territory anyway. So cost ++ Rotrex is a nice piece of kit, but imho the price cancels out most benefits. With 200E eaton MP45s on ebay its a no brainer. Screw the slight benefits in efficiency if you can save 2000E I say ![]() All of this for the sake of discussion off course. Its an opinion, not gospel. A wheel to steer the front of the car A pedal to steer the rear |
12-28-2010, 01:26 PM
Well... to be talking about my car...
I have D2 coilover kit - cusco strutbar - HKS mushroom airfilter - Poly-urethane bushings and under car struts... (dont know what else) Rust has been dealt with for 99% Looks are freakin ugly - need to fix some small things like sand the boot and fix corner of carbonfiber hood. Other than that the car is just superb. My 4age engine has not run 115.000 KM yet... it is in almost mint condition if you ask me. Have treated the car to new (normal) brakes all around and also renewed the engine like - belts - waterpump - radiator etc. This garage I spoke with are gonna talk with me next week about a certain setup either be it silvertop N/A or WITH turbo. They probably also want to help me out with contests so we'll see what will happen. But when I go talk with him - I will bring the NoHachi story with me ![]() -DWG- Drift Wolf Gaming |
12-28-2010, 02:14 PM
Okami, take your time and get to know all options.
T50 transmission will not survive long abuse with turboed 4AGE. If you change transmission, here comes rear end (LSD, halfshafts). If you change that, you will need more braking power. If you make it that quick, it would be wise to have rollcage. After all that, your car cannot be daily any more.... I agree with NoHachi about "sweet spot". 150-180 bhp is extremly fun in AE86, and you will preserve reliability and drivability. Personally, i would go to different engine/transmission if in need for 200+ bhp for "everyday". And there is insane number of possibilities for engine/tranny swap. |
12-28-2010, 02:16 PM
Its your car and money, so good luck with whatever path you choose. Just remember that garages are great at suggesting those paths that will make -them- the largest amount of money.
User(s) browsing this thread: 16 Guest(s)
