4age Gas smell
07-02-2012, 01:44 PM
4age Gas smell
Hi, I have an AE86 with 4age motor without tvis and it gas smell. When I start up the car on morning I get white smoke and the exhaust is dropping out some water. Sometimes I get some black dust on the rear. Anybody knows whats wrong?.
Thanks. |
07-02-2012, 01:56 PM
4age Gas smell
In general:
white smoke -> water black smoke -> oil or gas If white smoke lasts for 5-10 seconds, most possibly water is condensing somewhere. Are you driving your 4AGE hard ? Happens on various engines. Black smoke can be various things. Oil or gas, bad piston sealing (pistons, rings, valve stems...) OR to much fuel (various reasons). |
07-02-2012, 04:12 PM
4age Gas smell
I also have sometimes gas smell inside my AE86, i guess it's due to two holes on the trunk floor (maybe the car was GPL some time ago) and the smell goes in by those, although they are sealed!
About the smoke... i got no smoke.... and my oil consumption is sometimes big... depends on the type of driving i'm taking.... The white smoke i get sometimes it's water on the muffler caused by night's humidities.... Trying the Castrol 10W-40 for now and see if it goes well! ![]() |
07-02-2012, 04:18 PM
4age Gas smell
when the car accelerated the gas smell increases, does not waste oil, gasoline is closed to the maximum for the inspection.
no smell of burning oil, just a bad combustion. |
07-02-2012, 04:21 PM
4age Gas smell
pack Wrote:I also have sometimes gas smell inside my AE86, i guess it's due to two holes on the trunk floor (maybe the car was GPL some time ago) and the smell goes in by those, although they are sealed! I use 20/50, first used 15/40 but change |
4age hitting gas too quick means engine stalls - what is the issue? | Ryo | 20 | 30,539 |
06-27-2018 11:15 PM Last Post: Ryo |
4AGE - Engine Smoke and Smell | pack | 10 | 15,294 |
04-20-2017 05:06 PM Last Post: Bean |
Clutch burnt smell | izanagi | 10 | 15,049 |
09-05-2014 05:41 PM Last Post: allencr |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 6,422 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 8,077 |
