4age bigport head: port & polish
10-18-2006, 08:40 PM
jamiemirror Wrote:BenR Wrote:A good 4age head reqiures ALOT of work to completely reshape the ports, account for casting shift, reconfiguration of the valve seats geometry, valve modification etc. |
10-18-2006, 09:17 PM
Quote:stock 4age comes with 5 angle seats. Are you sure ? Sounds too strange for any production head. |
10-18-2006, 09:35 PM
A few production heads run 5 angle, its simply down to the cutter insert they use, adds no real cost.
10-18-2006, 09:52 PM
Just for additional reference. And some bluetop specs from AE92 site: http://www.ae92gts.com/ae92gts_engine_specs.html Quote:Valve seats Refacing angle 30°, 45°, 60° |
10-18-2006, 10:52 PM
to BenR
you cuted valve stem guide, you dont worry about your valves? http://www.coreygarage.prv.pl |
10-18-2006, 11:12 PM
nope, i dont worry.
It is only cut on the exhuast side, which sticks out a very minimal part in stock trim. |
10-18-2006, 11:18 PM
thanks
11-08-2006, 07:08 AM
Hi BenR I got a question about your porting job..Why do you remove material all around the cylinder bore line around the chambers?:
(For the image can you right click and open it i dont know why the image dont work when using left-click sorry ) Or can you tell me what serve this deck and how much material have been remove from Z axis? Here my second question, i projected a porting job on my 4age smallport 16v head , and here my idea for the chambers... My idea is to reshape the chambers to the cylinder bore-size for more sqish area do you think this is a good think or it will ruin the head? Sorry i hope im not too off topic since the question is about porting. Thank a lot in advance Ugo |
11-09-2006, 05:47 AM
Up!
If nobody elese know what im talking about dont hesitate please |
11-09-2006, 10:12 AM
Your question was directed to BenR first...
IMHO 1st question - these are squish areas. 2nd - I would keep them stock - just polish and round the edges. That way this head will be less prone to detonation with hi-CR pistons. Removing material from squish areas will not ruin the head but will not improve it either. I can't imagine how reshaping the chambers to the cylinder bore-size will give you more sqish area - please explain/draw ? |
4AGE cylinder head plug removal | Ivan141 | 5 | 2,023 |
Early tvis red top from e9 gti small or bigport? | Ryo | 3 | 7,444 |
10.8:1, 264/256° Bigport | nyberrg | 4 | 6,280 |
06-12-2017 09:57 AM Last Post: nyberrg |
Small Port Swap | Alex170984 | 1 | 4,139 |
11-21-2016 01:46 PM Last Post: Alex170984 |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,321 |
